Question about Sony CDP-C910 10-Disc CD Changer
Disc draw does not close fully. The draw closes but the armature that holds the disc does not engage. Is is possible the drive belt is slipping and not allowing to engage the armature?? Advise please Thanks
    Genius:
  • 1,112 Answers
Hi:
This is ususally a indication that the unit is either out of timing, or like you suspect a worn drive belt, most modern DVD players use gears, but it could very well be belt driven, seems the clamper is closed when the tray trys to go in.
Posted on Nov 09, 2010
LG DRT389H will switch on OK but the disc draw will close when a disc is loaded, but comes straight out again and will not play.
Hello
There is a loading motor and a belt associated with it, connected to a gear wheel assembly that pulls in the disc tray as well as gets it out. If the loading belt, said above, will get loose, the disc loading tray wont get into it properly. There is a sensor switch fitted inside the loading mechanism, which senses the proper tray in action, as this tray will touch it when it ahs been fullly loaded. Due to any reason, the switch said above does not engaged properly, the main system control IC will detect the loader position to be improper, and will give command to eject the tray. That is now happening to your DVD player.
If you have knledge and experience, just open your DVD player. locate the loading belt, and repalce it with a new one. You can buy this belt from most of the electronic sparepart selling shops at your town. Just keep the old belt in hand as a sample, when you go to buy a new one. OK
WISH YOU A HAPPY PROSPEROUS 2012
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 27, 2011 | Televison & Video
CD Player Tray keeps opening and closing by it self
This is either caused by the drive belt slipping, the closed sensor being faulty or an obstruction to the tray.
Basically the tray isn't makeing it to or registering as being in the fully closed position.
May 02, 2011 | Tascam CC-222mkIII CD Player / Recorder
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Sep 30, 2010 | Yamaha CDC-675 5-Disc CD Changer
Cd player drawer will not stay engaged when a disc is inserted
By not engaged i'm assuming you mean that the disc draw closes then opens again almost immediatley. This would indicate that the disc draw limit switch is not being activated by the draw or the switch has failed.
This is usualy a small sub-miniature micro switch activated by the draw itself, Sometimes a very light spray of switch cleaner into the micro switch will effect a cure. The switch gets a fairly hard life so it is more advisable to replace the switch.
Mar 16, 2010 | Sony Audio Players & Recorders
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
Dvd tray does not stay closed when you insert a disc it closes for a little bit then reopens
Hello.
There is either something that prevents the DVD tray from closing, make sure to insert the disc fully in the circle or if it isnt that the rubber belt in the DVD-drive is stretched out and not strong enough to close the tray completely when a disc is inserted, this is a known issue of these drives and often causes the drives not to open properly as well.
You can solve this either by replacing the belt or you can do a little trick which fixes the drive in 90% of the case.
How to do this is shown here: http://xbox-experts.com/e/tutorial.php?n=dvdopentray
I hope this helps.
Kind Regards,
Wilhelm@Xboxexperts.com
Mar 02, 2009 | Microsoft Xbox 360 Console
The door open by itself
This can be caused by the drive not closing properly. Usually caused by a slipping drive belt or a faulty micro switch.
If it is a slipping drive belt then the draw closes but the laser assembly does not get lifted into place. If the belt is slipping either replace it or try belt anti slip spray.
If the micro switch has failed then the draw closes but the micro switch doesn't tell the CPU that it has closed so it times out and opens again thinking it has failed to load the disk. If the micro switch has failed it either needs cleaning or replacing.
Alternatively you could just replace the whole draw mechanism however this is normally much more expensive. There are other possibilities such as a faulty micro controller causing this but the two above are by far the most likely.
Regards, Andrew
Regards,
Andrew
Sep 15, 2008 | Audio Players & Recorders
Our sony hcd-hpz9 stereo will not allow the 5 disc changer to open. It will play disc 1 only. Any suggestions. It makes a rumbling noise. Is there a way to manually open the disc changer?
this is done by a belt drive. i have seen the belts get old and slip. try to gently pull the door open as you hit eject. If you get it to open and find that it will not fully open or close without assistance this is the problem.
Aug 30, 2008 | Sony Audio Players & Recorders
Sony CDP-C910 10-Disc CD Changer Logo
64 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
