Question about HP LaserJet 3055 All-In-One Printer
No print cartridge error
Whenever I turn on my printer, a No Print Cartridge Error comes up so I am unable to print or photocopy documents.
    Master:
  • 788 Answers
Are you using new HP cartridges or refills? Only HP cartridges have the proper chip in them for the printer to recognize.
Otherwise the contacts on the printer that communicate with the cartridge chip may be broken, bent, or out of place. Take a look at your cartridge, you will see a bunch of metal contacts. The ones on the side are electrical, the two that are near each other, they should be on the top of the toner or the one you are looking for. Look inside the printer for the matching contacts, they should be spring loaded, make sure they look ok, if not get the printer repaired. If they look fine and you suspect that they are making contact with your toner then maybe the electronics of the printer are faulty, have the printer repaired.
Do you have an old cartridge to try to see if the printer sees it, how about a new cartridge, maybe the chip in your current cartridge is bad.
Posted on Jun 16, 2008
How do i clean my printer , showing me 10.000 supply memory error?
The Error code 10.*** indicates the following as per HP Error codes manual:
The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
XX Description 00 memory error on the cartridge or 01 memory device not found
10.00.00 Black print cartridge
10.00.01 Cyan print cartridge
10.00.02 Magenta print cartridge
10.00.03 Yellow print cartridge
Recommended actions as per HP Guidelines:
a) Reinstall the print cartridge
b) Turn the product on and then off
c) If the problem is not solved than replace the cartridge.
Oct 24, 2012 | Office Equipment & Supplies
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
When trying to print a document I keep getting an error message stating, "Cartridge Error consult user guide
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 15, 2010 | Office Equipment & Supplies
My printer is printing blank pages. The test print prints all the colors though. But when I print a document all I get is a blank page. I just installed a new color cartridge.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 09, 2010 | Canon PIXMA MP470 All-in-One Printer
When the printer is turned on it states: ink system failure. Unable to print. Refer to printer documentation. Error Oxc18a0001.
possible causes of this:
  • loose or improperly installed ink cartridge
  • damaged cartridge
  • dirty print head
Solutions:
  • check cartridge connection, try to remove and reconnect
  • replace damaged cartridge
  • clean printhead using the printhead cleaning utility software of your printer
Oct 21, 2010 | HP Office Equipment & Supplies
I have the HP photosmart C6280 printer.. 2007 edition and it has all different color ink cartridges, the yellow ink is almost out so it will not let me print anything. I am just trying to print off a word...
http://www.fixya.com/support/t6288403-hp_8050_printer_message_says_color
Sep 30, 2010 | HP Photosmart C6280 Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
New cartridge inserted, received error
Hi can try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 03, 2009 | HP Photosmart 3210 Printer
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge error
try to take out the ink cartridge and check if there are any leaks inside. check also if there is still ink left in the cartridge. have the ink cartridge replace and the printer cleaned.
hope this helps.
fixya!
Jan 29, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP LaserJet 3055 All-In-One Printer Logo
71 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
