fritzglas,
It sounds like a interference issue. Sometimes a TV (Usually LCD) or other equipment can generate enough heat to interfere with the IR sensor.
If function returns when you go right up next to the receiver then there is most likely something causing that interference. If that's the case remove possibly sources or turn equipment off and power on 1 by 1 until you isolate the problem.
Another solution if you have a spare remote, or order one, is change it from IR to UHF and bypass the possible. This can be done with remote model's that say IR/UHF Pro on the back at the top.
If you can provide more information about your setup, or if those steps didn't work let me know here or at
[email protected] and I would be happy to check it out further with you.
Tommy Faust
DISH Network
