Question about Sony KDF-42WE655 Television
My light lamp went out. Is it reasonable to just replace it by dissassembling the housing. This monster is too big to haul in and out of the apartment?
  • 8,197 Answers
The lamp is easy to replase on the Tv. Go to the link below then click on operating instructions. Page 16 - 22 tels you how to replace.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF42WE655&LOC=3
On this link below you can get the lamp.
http://www.google.com/#q=sony+kdf-42we655+lamp&hl=en&prmd=ivs&source=univ&tbs=shop:1&tbo=u&psj=1&ei=j6PYTK8gisSwA_Dp2JgI&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDcQrQQwAA&fp=4b3eeabb4c23868d
Good Luck
Posted on Nov 09, 2010
What is a 777 dump truck used for
It's used to haul 100 tonne payloads in mining or quarry work.
Jan 31, 2015 | Cars & Trucks
How do i replace burned out lamp
It's very simple, on the back of the TV you will find a square vented plastic cover held in by 4 screws. Remove the screws, you'll now see the lamp housing being held in by 1 or 2 screws. Remove the screw (or screws) you'll now see the lamp housing, it has a metal handle that pulls the lamp (and housing) straight out of it's slot. I purchased mine at Lamp Monsters on Amazon (Samsung Lamp with Housing BP96-01600A) for about $30.00. You will see them priced from 30 bucks up to and above $300 bucks! Good luck I hope this helps! TomD
Sep 27, 2014 | Panasonic PT-56LCZ70 56" HDTV
Samsung HLR5667wx/xaa. Power surge took out tv. Replaced bulb and the bulb works, but tv wont come on and lamp light is flashing.
Hello, it sounds like the color wheel may have failed. Was there any noises, like a high pitch sound before it went out? If the color wheel isn't turning at proper speed, the set won't start up by shutting down the lamp protection circuit.
Jul 10, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
Replaced the lamp in Samsung HLN437W and picture is brighter but not bright enough even after adjusting brightness. Also lamp LED still blinks
A few questions: was replacement just a bulb or bulb with housing and was it OEM lamp from Samsung?
If lamp light is still blinking the issue it has is there---other possible reason would be a ballast that is not bad but putting out low voltage to the lamp or the supply voltage to the ballast is low for some reason.
Actually the set should if the lamp light is still blinking shut off the lamp.
Also are you hearing any high pitched or fan like sound when the set is on?
May 16, 2012 | Samsung HLN437W 43" Rear Projection HDTV
Samsung Model # HL-P5674N
nothing else is required except inserting it right which is not hard==lamp does not seem to be your problem, Other things will cause this issue as well, it is not always the lamp that is bad.
One thing you might want to do is remove here the new lamp unit to make sure it went in clean and straight, With it removed look in the direction the lamp faces for the color wheel, look to see it is intact and not shattered, I attach a photo.
I mention as this is also a common issue in this set, usually proceeded by a high pitched fan like sound or even when failing a grinding noise.
Apr 04, 2012 | Samsung HCM4215W 42" Rear Projection...
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Sony projection television lamp replacement...
hello the last light at the bottom of the tv will flash this will tell you the lamp as burn't out i would buy the lamp in the housing it just makes it easyier to install when you do install it make sure
Nov 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Replace lamp led light
Have you reset the lamp timer?
Was the lamp module sitted properly?
Remove the back panel and vacuum all the dust.
Also use compressed air to blow out the dust from the inside.
Do not blow into the fan on the right as that will get the dust inside the lamp housing.
Nov 22, 2008 | Panasonic PT-50DL54 50" Rear Projection...
1995 Jeep Grand Cherokee Laredo, "rear lamp failure"
guys i had this problem it was the brake light in the window center bulb was bad drove me nuts changed all the bulbs in the third brake light and it went away
Aug 16, 2008 | 1995 Jeep Grand Cherokee
Sony kdf-60xs955, rear projection tv
There is a Thermal fuse under the lamp housing that opens up and Sony has a New style fuse to replace it with, it opens up one of the p/s lines to set code 6, replace with new thermal fuse and test. You will want a Skilled Professional to replace this fuse as it does require some dissassembly and removal of light engine to remove fuse from under lamp housing to put new one on side of lamp housing.
Jun 19, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-42WE655 Television Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
