New Sanyo Model# DP26648
After setup can only get 1 Station.
  • Anonymous Jan 11, 2009
    have new sanyo 26" tv trying to pull up addl ch's above 22 how do i do this
TV was not at channel 03, as soon as it was we received all channels.
This is without a doubt the dumbest item ever posted.
Posted on Jun 19, 2008
2008 sanyo lcd tv DP26648 power turns on but no picture or sound
likely a mainboard or power supply capacitor issue.
if you have the soldering skills fix it, otherwise time to replace the TV.
If you can de-solder and solder in new capacitors make sure you are using high quality capacitors be very causious of capacitors purchased from auction sites.
Apr 30, 2014 | Sanyo DP26648-R 26 in. LCD TV
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
Sanyo 26'DP26648 tv need tv code
You're in need for a universal remote setup code for this TV, I assumes and posts this solution. The setup codes for Sanyo brand TVs are given below. If you want more details about the setup proceedings, and more codes, check this link.
0049 0097 0110 0004 0268 0012 0108 0180
Jan 13, 2013 | Sanyo DS24205 24" TV
We bought a 32" Sanyo LCD Hi-Dif digital
We do not sell parts through fixya. However, shopjimmy.com, http://www.shopjimmy.com/catalogsearch/result/?q=DP26648, has many parts for the DP26648 from TVs that were damaged in shipping. These are used but have only been run during QC testing at the factory. The power supply is listed as out of stock but lists for $64 when they have it.
Some other Sanyo TV parts are available here: http://www.partandproducts.net/sanyo-tv-parts.html . This site also lists the power supply as out of stock.
I hope this helps.
Apr 11, 2011 | Sanyo Televison & Video
Neither "solution" is a solution. Anyone actually
Your problem is the T-con board. This is gone bad/faulty. I would advice you to replace it with new T-con board and your unit will back to normal again. You may look for the replacement online. Try ebay.com or shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 16, 2011 | Sanyo DP26648-R 26 in. LCD TV
Looking for new or used main motherboard
Required main board for Sanyo DP26648 lcd tv is available in Shop Jimmy.com for $70
Click to view image of board, make sure your tv model is as shown in your question headings.
Thanks.
Oct 23, 2010 | Sanyo DP26648 LCD TV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
