Question about Alpine KTP-445 Car Amp
Need a wiring diagram for alpine ktp445 amplifier to install on no alpine system
    Sniper:
  • 59 Answers
need a wiring diagram for alpine ktp445 amplifier - bassmekanic_3.jpg For this end of the plug: I would plug the other end of the KTP-445 directly into it and match the color of the wires off the other plug, remember to write them down, but most of the wires look like standard plug wires on most stereo plugs. When this is complete you should be able to snip this end off. Then wire it the wiring harness inside the dash (using the notes you took on the wire colors)
bassmekanic_4.jpg This end of the plug looks to have all the standard wires that most after market stereos have, clip this end off and wire it to the wiring harness on your current stereo. (You may not use all the wires, just tape them off because you probably won't need them anyway)
This is just my opinion on how it would be done, I have not tried this myself. But since most aftermarket stereos have the same kind of wire set up I do believe this could work.
If you decide to try it, please give some feedback so others can figure out how to do this also.
Posted on Nov 09, 2010
Installed a used but tested good deck in my truck, Alpine CDE133BT and I have no sound from wired speakers but my amp and sub are working?
The installation, instructions and wiring diagram are here. Buying used is full of dangers. I would want to see it working before buying.
Alpine CDE133BT Google Search
Dec 14, 2016 | Alpine Car Audio & Video
I have a alpine CDE 152 head unit in my car and just put in alpine SPR 60 coaxial speakers in the rear. thought the head unit would be enough and want more punch from the base.. do i need an amp or i
get the alpine ktp445 mini amp ,it should be compatible (check your manual for your HU it will say ) its a plug and play install and you will hear a great improvement as I did and still got mine with the alpine cda 117 .
Apr 04, 2014 | Alpine Car Audio & Video
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Im adding a alpine cda9884 headset with a ktp-445 already installed on it into my 96 grand cherokee. I am. Going from the ktp445 straight to the speakers. My problem is i cant get anything at all out of...
how is the signal going from headunit to the power pack? Should have a harness from the power pack to the deck (h/u). then out to the factory harness in the jeep. remember there is an amp under rear seat so you need to bypass that to make everything work. yes the blue/white wire from deck to blue/white wire ath the power pack (amp) should be connected in order for the power pack to turn on.
Oct 20, 2010 | Alpine KTP-445 Car Amp
Need wiring diagram ktp445 to be installed on a NON alpine unit
please, I need wiring diagram for a alpine ktp445.... to be installed on a NON alpine unit.
thx
dave
Dec 06, 2009 | Alpine KTP-445 Car Amp
How do i install mrp m1000 to two type r 12s step by step.
Hello chadbcavanau,
See the link here for a step-by-step install with photos and amp wiring diagram.
First you need to purchase an amp wiring kit (minimum 4 gauge power and ground). If your vehicle is equipped with the stock radio, you'll also need to purchase a line output converter (LOC).
Hope this helps.
Sep 23, 2009 | Alpine MRP-M1000 Car Audio Amplifier
'04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Sep 05, 2009 | Car Audio & Video
Need help!!!!!!!!!!!!!
ALPINE ELECTRONICS OF AMERICA, INC.
19145 Gramercy Place, Torrance,
California 90501, U.S.A.
Phone 1-800-ALPINE-1 (1-800-257-4631)
Mar 16, 2009 | Alpine MRD-M500 Car Audio Amplifier
Alpine CDA-7840
Some 4-Runners have a factory system that uses a separate amplifier to power the rear speakers. In this case you need to activate the amplifier using the blue/white remote output from your Alpine deck. It sounds like the wire that activates the amplifier is currently attached to the deck's blue "power antenna" output, so that the amplifier is only on when the tuner is selected. Disconnect whatever is attached to the blue wire behind the deck, and attach it to the blue/white wire instead. That should solve the problem.
Jun 09, 2007 | Alpine CDA-7840
Alpine KTP-445 Car Amp Logo
2,207 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
