Question about Samsung LN32A540 32 in. LCD HDTV
2008 Samsung 32" Flatscreen 720p Channels are
  • Jack welsh Sep 10, 2013
    I need the tv channel setting (ie 35, or 74 or 3 prior to using the remote control.
  • Samsung Master
  • 736 Answers
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Posted on Nov 09, 2010
When hooking up HD Cable box I get "not supported
You most likely have to set the Cable Box to a specific resolution. Because that model only provides 720p/1080i, the box must be set to match that. You may need to use the yellow/white/red Composite output on the box to the tv first, so you can access the boxes menu and set it to 720p or 1080i, then I recommend using Component cables (Red/Blue/Green with white/red for audio) out of the box in to the TVs "Component 2" input. Now you should get a good HD picture. If you still can't get it to work, give me a reply with details and I will get back to you.
Jan 14, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Invalid format
If you get that across all inputs or channels then your digital board is bad. If you get it only on one input such as HD cable box, HD satelitte receiver or Blu_Ray player then they are set for the wrong output on that connector. The TV most likely will only accept up to 720p or 1080i....
May 19, 2010 | Olevia LT32HVE 32 in. LCD Television
Toshiba 46HM95 wont display 720p from dtv antenna other tv works
lets start with the easiest first.does your tv in the menu option offer an input output source like 720p or 480p?on my set i can change to any format.maybe yours does too.let me know and we go from there.
Mar 04, 2010 | Toshiba 42H81 42" Rear Projection...
HDTV and cable box; no volume on channels higher than 99
Can you tell me, is the set top box connected directly to the tv? (i.e. not to a surround sound receiver or anything)
Mar 13, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
720p output doesn't work
The problem might be that the set can not handle the change in signal. Try setting the AVR-247 to 720P first then turning on the set. Or manually set the TV to receive 720P then change the AVR. TI believe that you have a connectivity issue where the two units are not speaking the same language at the same time. Update this with your results and please post the TV make and model.
Thanks,
Dan
Apr 01, 2008 | Harman Kardon AVR 240 Receiver
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Samsung LN32A540 32 in. LCD HDTV Logo
414 people viewed this question
Jerry Greenberg
Jerry Greenberg
