Question about Toshiba Satellite Pro L300 Notebook
Blank computer screen - Toshiba Satellite Pro L300 Notebook
  • 2,296 Answers
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Posted on Mar 01, 2011
Screen stays blank after start up. Grafic card?
take battery out then get rid of dust then restart it if still doesn't start make sure adaptor works correctly, if problem is still there its a computer error/bug
May 30, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
Screen keeps going blank
Hi Wendy,
Sounds like a faulty or loose component inside the screen.
It can be caused by many loose or faulty electronic parts. Best you take it to a repair shop to have it checked out.
Best wishes,
Graemevm
Apr 06, 2010 | Computers & Internet
Blank screen
I'm assuming that it turns on. Make sure that it's connected. Try connecting it to another computer. If it still doesn't work unplug it from the computer and turn it on. If it doesn't display a self test screen it may be broken.
Feb 02, 2010 | LG W2242T-BF Monitor
When i'm online, my computer screen flickers then goes blank with a white screen. The computer is still running the screen just goes blank. how can i solve this problem? and sometimes when i turn on the...
Your computer is infected with spywares.You need to scan your computer for spywares from a good antispywares software like Malware byte, SuperAntispyware etc.
Jul 11, 2009 | Acer Aspire 4520-5141 Notebook
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
White blank screen
Hi...there,
If you got a white screen, then you need to replaced a new AD board. AD board is a piece of component that you plugged your VGA or DVI cables to the monitor. Good lucks, Have a nice weekend!
Sep 11, 2008 | Relisys RLT1720 17" LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
I have a panassonic 50" plazma tv, when using it as a pc monitor the screen goes blank how do i stop this, many thanks, patsy
Does the screen go blank after the computer has been sitting unused for a while or is it immediately blank and does not show a picture. If it goes blank after a while, look in your power settings under control panel on your computer and set the monitor cut off to NEVER, also check your screen saver settings. If it does not show a picture at all check the user manual of your TV to see the supported computer resolutions and then check under display settings on your computer to see if the resolution that you are using is compatible. Hope this helps.
Apr 02, 2008 | Televison & Video
Toshiba Satellite Pro L300 Notebook Logo
178 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
