Question about Linksys Wireless-G WRT54G Router
I cannot connect to my my router from any wireless device i have reset it so many times also i cannot find the installation cd please help thanks
sandrew
  • 2961 Answers
SOURCE: compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
Posted on May 17, 2007
SOURCE: Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
Posted on Mar 16, 2008
  • 33 Answers
SOURCE: my linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Posted on Jan 25, 2009
  • 73 Answers
SOURCE: Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Posted on Apr 13, 2009
  • 109 Answers
SOURCE: WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Posted on Jul 09, 2010
Hi I install a wireless router and after a few months couldn't get wireless connection try everything now i can't find my cd to install it
hey,
you dont need a Cd to install your wireless router.
If you are looking for a CD , download the same from the routers site.
Or press the small reset button on the back of your router to reset the entire network, then connect the router to your laptop/desktop by a wired connection, navigate to your routes default webpage (details behind or benath the router) and then login and configure everything again.
Cheers!!!
Feb 26, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
I'm trying to set up 2 computers in a wireless network. I have a D-Link DI-624 router. Where do I plug in the flash drive on the router?
Hi norman66, the wireless flash drive you connect to the computers that do not have a wireless card, not the router. First install the CD on the computer and then insert the usb device.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast free support today. Thank you :D
Apr 30, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
My hardwired computer gets on line but the other two wireless can't. I've reset the router several times but no luck. Checked all the connection still no luck.
Check if the router is assigning IP addresses to the Wireless devices. Also se if you hard-wired desktop has been assigned an IP address manually. Else try to assign IP's to wireless devices manually (Depends on your setup)
Please rate if helpful.
Thanks
Apr 14, 2010 | Linksys Wireless-G WRT54G Router
I just installed my new zyxel router on my desktop. Went thru all the steps and now it is time to install the CD into my computer to become wireless. Question: I assume I install this CD in my laptop since...
the cd is likely an animated wizard that will guide your through the process of setting up your router (ex. how to connect each component and how to access the router's configuration page.) I doubt that you need the cd to actually connect your computer wirelessly.
what you need to do your router
1. the router should work right out of the box, usually what you would do you router is to configure some security (ex, change router's name, set password/network key/passcode - so your neighbor does not steal the internet your paying for). you need your router's manual and follow the instructions on the section usually called wireless security
what you need to do your wireless computer.
1. assuming you have configure some security on your router you need to know what your router name is (ssid) and your encription method configured on your router (wpa, wep. etc) and your key/password/passcode configured on your router and proceed with the following instructions depending your operating system:
xp
vista
for windows 7:
Start → Control Panel →View Network Status and Tasks → Change Adapter Settings → Wireless Network Connections. Right-click Properties, and then the steps are the same as in Vista and Windows XP. (or similar)
hope that helps and post back if you have any specific questions on the info offered!
Dec 28, 2009 | Computers & Internet
How do i install my WIRELESS G ROUTER without the cd
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
Sep 21, 2009 | D-Link DIR-300 Wireless Router
Netgear wpn824v3 slow connection, etc
MTU Adjustment
1. Access the web-based utility of the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
2. Adjust the MTU setting.
a. Click on the WAN Setup under Advanced tab.
b. Lower down the MTU size to 1492, 1400, 1358 or 1300.
c. Click on the Apply button.
Note: You may verify from your ISP the recommended MTU size you can use.
May 02, 2009 | NetGear RangeMax WPN824 Router
No CD need to set up Linksys Wireless G Router
Router setup
You do not have to use the cd. Follow these instructions:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WPSM54G No Device
Do a reset on the print server. To do this, hold in the reset button on the back, unplug, then plug in and continue to hold for 10 seconds. Your setup should now detect the print server
Nov 11, 2008 | Linksys Wireless-G WPS54G Print Server
How to connect wire less connection with my laptop,
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Aug 11, 2008 | Linksys WRT300N Wireless Router
I don't have a cd installation ...have no idea how to hook this up..please help
You probably dont need to get any cd, but here is a basic setup. 1. First reset router to factory specs..there is probably some sort of reset hole on the router. With router disconnected Stick paper clip inside and hold while you turn back on router about 10 seconds. 2. Next with computer and Modem turned off plug the Ethernet cable from the modem to the WAN port on the router. 3. Next plug an ethernet cable from the router to the PC. 4. Turn on Modem, then PC it should get you on the internet. 5. Usually the Wireless portion is defaulted to ON, so knowing you have a wired connection, you can now try with your wireless device. 6. Windows will find this signal and it will give you an option to connect to it. When you get an IP address, you will be on. To get into more advanced setup, you will need to get into the router. Try It you should be alright
Feb 27, 2007 | Compaq iPAQ Connection Point CP-2W...
Linksys Wireless-G WRT54G Router Logo
21 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
