Motherboards
Generic problem for all Motherboards
I/O ports and Ps2 issues
shared by 2 users
posted by gerard76 on Jun 16, 2008
No joy, definately not a grounding issue. I fear it maybe something simple that I maybe overlooking as I am still relatively a novice when it comes to PC builds.
Can I ask ( it may sound silly to you but) when installing a new motherboard and processor does the required DDR have to be brand new/clear of residual memory in order for CPU to initiate?
Comment posted on Jun 17, 2008
Nope, no video. The mother board doesn't pick up the monitor/keyboard/mouse or speakers or anything connected to the PS2/USB ports to the rear.
I do have "feet" between the motherboard and case too.
STILL BEING STUBBORN
Nothing wrong with the motherboard, having replaced it for another identical one only for the same problem to arise!
I have a 20pin ATX power connection in a 24pin socket, but there is also a Secondary 4pin ATX power socket for which my PSU (ATX) doesn't have a cable supplied. Should or would this affect the motherboards power supply?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by vmns on Sep 21, 2008
I bought a used computer with biostar m7viq motherboard that ps2 mouse doesn't work at all, tried 3 mice and still doesn't work, usb mouse works fine, any idea
Solution #1
Thanks for Trying (70)
samisam
Rank:Wiz Wiz
Rating: 81%, 48 votes
not at all. you can put any memory stick as long as it's working.
hmmmmmm.. so you do get video, but can't move the mouse or do anything with the keyboard. oh hold on, do you have any "feet" between the motherboard and case??
Rating Locked! (?) gerard76 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I/O ports and Ps2 issues:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Intel DG31PR Motherboard
Since my XFX 650i motherboard got damaged I bought Intel...
Intel Motherboard
every time i open my computer i see this: error ...
Motherboards
Hi, I assembled a PC comprising of the following...
Motherboards
SiS 760 Display Adapter not functioning. I also have...
Jetway (V2MDMP) Motherboard
Good people out there. can you please give me a mobo...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
