Question about Vector Spotlight - 1 Million Candles Power, Model# VEC127Y
What volt and amp charger does the vec127y use
  • 283 Answers
It uses a Class 2 Transformer to charge the battery. The input is 120V AC 60Hz 9W. Output is 12VDC 300Ma.
Posted on Nov 10, 2010
CAN i CHARGE A 36 VOLT BATTERY WITH A 24 VOLT CHARGER?
No of course not.
The charger has to be the same as the battery it is charging. On BIG batteries, it also has to have the power to handle the higher amps as well.
  • 36 Battery Charger Volts - 36 Battery Charger Volts - Deals! Ad · www.HomeGardenPro.com 36 Battery Charger Volts - Deals! Your Home, Your Style - Redefined.
    Handpicked Collections · Great Deals - Low Prices
  • 36 Volts Battery Charger ' Calibex.com Ad · www.Calibex.com/Electronics Cheap Prices and Huge Selection 36 Volts Battery Charger on Sale!
  • 36 volt battery charger in Batteries & Chargers ' eBay www.ebay.ca > Search > 36 volt battery charger Find 36 volt battery charger and 36 volt battery from a vast selection of Batteries & Chargers. Get great deals on eBay!
  • 36 Volt Battery Charger ' eBay ebay.com Find great deals on eBay for 36 Volt Battery Charger in Forklift Batteries and Chargers. Shop with confidence.
  • 36 Volt Battery Chargers ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Chargers in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Chargers - Electric Scooter Parts www.electricscooterparts.com/36vchargers.html 36 Volt Battery Chargers for Electric Scooter, Bicycle, Pocket Bikes, and Go-Karts. We have 36 Volt (36V) battery chargers in stock.
  • 36 Volt Battery Charger ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Charger in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Charger eBay
    Sep 20, 2016 | Health & Beauty
    I need a phone charger for a Samsung galaxy note 3 can you tell me what will work for my phone! I had one of your brand before! Thank you!
    Any micro usb charger , rated at 2.0 amps. You can use a 1 amp charger but will be slow. All usb devices are 5 volt, don't worry about volts, just amps. Note 3 = 2 amp charger
    Sep 04, 2015 | Samsung Cell Phones
    Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
    not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
    And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
    At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
    The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
    The charger at 24 Volts must be 26-28 Volts. to charge well.
    The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
    3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
    5 Amperes Charger needs 2 Hours charging an a quarter
    All of this is at DC Current.
    Luck.
    Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
    How much amps does the charger need for rhe 6volt
    Hello dear
    6 Volt battery charger needs 1.25 amps
    It will vary according to the other ratings of the charger. & volt Charger is also worked with 3.25 Amp.
    Regards
    Rate the answer if it helps you
    Mar 14, 2011 | Health & Beauty
    What tip polarity do I use to connect an after market charger?
    The short answer is "The tip should be set to positive (+).
    I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
    REPLACEMENT VECTOR VEC127Y BATTERY
    I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
    UNIVERSAL AC ADAPTER
    I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
    Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
    The small flashlight on the handle will not turn off. When I press the button it goes off and then when i release it comes back on- can you assist?
    It sounds like your switch is defective, unfortunately Vector lights are Non-Servicable except for replacement bulbs, batteries and chargers, so I don't think it is worth fixing.
    Mar 19, 2010 | Vector Spotlight - 1 Million Candles...
    Want to buy a charger for Shark Cordless Sweeper
    If you have the old charger, look at the pin and read the output. Many electronics clearance stores sell a generic charger which will match the output in volts and amps as long as you find the identical pin configuration. Volts may exceed the original battery rating by 20%, amps can as well. IE I have a 9.6 volt charger on my 7.2 volt battery pack.
    Sep 06, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
    Vector Sport Spot 1,000,000 candle power spotlight
    6 Volts, here is info from site.
    VEC127Y
    VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
    • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
    • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
    • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
    • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
    • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
    • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
    • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
    • INCLUDES AC AND DC CHARGING ADAPTERS
    • INCLUDES BUILT IN HANDS FREE WORKSTAND
    Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
    Charger for 12 volts 7 amp battery smf
    you need to go to a **** smith store and bye a kit to do this cheers peter
    Apr 18, 2008 | Ryobi Multi-Volt Battery Charger
    Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Logo
    856 people viewed this question
    Top Vector Camping, Backpacking & Hiking Experts
    Barry_IA
    Level 1 Expert
    Jim London
    Jim London
    Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
