Question about Cameras
It's showing.. !card error. The card is in properly and I just charged the battery
  • 489 Answers
Don't know what kind of camera you have, so it's hard to give specific detailed help.
If your camera uses CF memory cards, you probably have bent pins in the card reader.
If your camera doesn't use CF memory, then you most likely have a problem with the mainboard (like a motherboard) of the camera and it needs to be replaced. You can look online for a used camera and pull the board yourself to do the repair, or send it in to a shop like ours and have it done for you.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Posted on Nov 09, 2010
Took out memory card to transfer photos. returned card to camera and it indicated memory card error shut down leaving lens out.
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery.
Never remove or insert a memory card while the camera is turned on!!!!!!
Jun 22, 2014 | Pentax Optio Cameras
Sim card removed battery Completely dead
plz check the battery,if it is ok then your phone needs to be serviced
Jul 23, 2008 | Nokia N95 Cellular Phone
New vu just blinks off and on, will not show its charging just blinks
Try removing the battery and SIM card and let it sit for 5-10 minutes. Put everything back and start the phone again. Make sure battery and card are in properly.
Jul 20, 2009 | LG Vu CU920 Cellular Phone
K 220i charging problem
i am mobile k220i charging propelam
Jan 03, 2009 | Cell Phones
1600 not charging
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. Try to change a new battery' check the battery terminal contact'.
sometimes is not properly alligned' or maybe your battery is loose in tha back houssing of your phone.
Nov 11, 2008 | Nokia 1600 Cellular Phone
Error E11 with DC4800 camera
This error "may" be associated with a battery problem. Is it possible that the battery is not charging properly.
Other things to try are as follows
1. Connect the camera to the AC adapter or insert onto the Camera Dock and press the Power button on the camera
2.
  • Remove all sources of power (batteries and AC Adapter) from the camera.
  • Remove the Kodak Picture Card or Compactflash Card.
  • Wait a few seconds.
  • Press the Power button twice.
  • Connect the appropriate Kodak AC Adapter to the camera.
NOTE: If you don't have the correct AC adapter, insert a set of fresh or fully charged batteries, according to the User's Guide.
3. The COMPACTFLASH Card could be corrupt. Reformat the card using a card reader or a PCMCIA card adapter in a notebook computer. ***Remember, reformatting erases all information from the card***
4. Try a different CF card as I have seen them fail causling errors.
Jul 01, 2008 | Kodak Cameras
Nikon D70
Greetings,
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. In my D70s I use Sandisk Extreme III memory and, knock on wood, have not yet had this error. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
-WN
May 12, 2008 | Nikon D70s Digital Camera
Anything I can do for a flash busy error 99 message?
Could be that the battery is weak, and should be replaced as it is not holding a charge.
Mar 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Troubleshooting with polaroid digital camera
I have a i1032 polaroid digital camera and when i turn it on it beeps 3 times and then automatically shuts off. the batteries are fully charged too.
Dec 26, 2007 | Polaroid i832 Digital Camera
Canon ds6041
The error 02 can come up when there is CF card problem : card not seated properly , card takes too long to come on line from the cameras point of view or if one of the the pins inside CF card chamber is faulty.
Sep 12, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
