Question about Canon PIXMA iP3000 InkJet Photo Printer
After printing about 40 pages my canon i850 gave me an overheated print head message. I cleaned EVERYTHING! because I was also getting a code which indicated the tank was getting full. I eventually replaced the print head. Now it goes though it's printing process but, the pages are blank. Asking it to clean heads or print a test pattern are also blank. Has new ink cartridges. I've done everything I can find suggested. It seems in working order just won't spit out any ink. Any suggestions before I pitch it? Thanks pga
  • pamaral Nov 09, 2010
    Well this makes sense but, when I installed the new print head I also put in new ink cartridges and followed the initial set-up procedures which pump a bunch of ink through the new print head so I don't see why there should be air trapped in the micro screen. I would buy this as an explanation when I tried to clean the previous screen. I had seen comments about this as a problem and followed the recommendations of flushing the screens and making sure the ink was reaching the heads. I don't understand why I keep getting the overheating code, perhaps because ink isn't flowing through the heads as you mentioned. The only tubes I saw when I took the printer apart to clean the filters were the ones which sucked the excess ink into the waste Tank which really is just a big filter. Are those the tubes you were talking about irrigating? Can't imagine that would be it since that's well after the ink should have hit the paper. Just pissed that I spent so much time cleaning it. Also that the recommendations said to replace the print head. That was about half the price of a new printer. Plus I upset that the Epson printed I bought prints much darker and duller. If you have any other idea I like to hear them. I'm going to accept your answer because you might be correct even though I haven't been able to resolve the problem. Nothing in the service manual was helpful. Thanks for listening to me complain. Thanks pga
    I believe the solution could be correct even though I couldn't solve my problem. Thanks
  • Canon Master
  • 12,061 Answers
OK what can happen is the Overheating of the print head assembly, can evaporate the ink inside the tubes going back to the ink tank, and then an air lock stops the new ink from getting from the tank through the tubes and out the nozzle... You must force the new ink to push it's way through to the nozzles, after that capillary action takes over.. Sometimes a syringe can be used to flush the pipes as it were. Unfortunately sometimes it's just not possible to make it flow again without considerable expense and mucking around.
http://www.devicemanuals.com/guide/Service%20and%20Repair/Canon/Canon-i850-Printer-Service-Manual-==TXpFeE16QTU=.html
Above is your service and repair guide for your printer.
Posted on Nov 09, 2010
Printing, but not full words Canon i850
Sounds more like the actual print head has become dried out and simply needs to be cleaned. This is a common problem with Canon Bubble and Ink Jet printers.
You should be able to remove the cartridge and then the print head shuttle that moves across the page. Once you have it removed, you will need to get a couple of Q-tip swabs and some DENATURED ALCOHOL, NOT RUBBING ALCOHOL as the water in rubbing alcohol will damage the printer head. Wipe the face of the printer head GENTLY with a moistened swab, you should see the dried ink dissolve, do this a few times until you see no further ink on the swabs.
Allow it to dry for a few minutes and then reinstall it into the printer. You will need to run the alignment function of the printer to ensure that the print is aligned properly. That should do it.
Cheers,
Keith
Sep 19, 2009 | Canon i850 InkJet Photo Printer
I have problems aligning printer heads on my Canon i850. I have clean the printer heads, replaced cartdridges, re-aligned them, but I still get lines through the printed material (phots mostly). No...
Please try to uninstall and reinstall your printer.
Clean your printer heads.
Perform a hard reset to your printer.
Print a test page.
Try using a different bond paper.
Make sure you are using original canon cartridge
If still you get an error. Replace your printer heads.
Aug 30, 2009 | Canon i850 InkJet Photo Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
7 yellow flashes not printing
hi welcome to fixya!
I believe there is no print head failure happening. I experience that one time, it only needs a new ink cartridge. Be sure to replace the right color!
have a nice day!
Apr 17, 2009 | Canon i850 InkJet Photo Printer
Canon i850 seems to be printing, but get only blank page
try cleaning the nossle of the cartridge , if that too doesnt work try cleaning the contacts of the cartridge holder, if that too doesnt work then take the printer to service center
Dec 19, 2008 | Canon i850 InkJet Photo Printer
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
Will not print
Remove and re-seat the print head. If need be the print head can be cleaned with hot water. YMMV but I've submerged my i850 print head for minutes at a time. Dry it off, blow it out, and it goes right back to work. Common problem if you're using non-Canon inks.
Nov 07, 2007 | Canon i850 InkJet Photo Printer
S520 will not print in any color
If you have tried to print a nozzle check page and no ink has been deposited on the page, then it might be a bad logic board inside the printer or a faulty purge unit. Both parts are relatively expensive to purchase. You might be better off looking for a used Canon s520, i550, i850, pixma 3000, or similar model to use the remaining ink cartridges if you can locate one in good condition and not more than 40 USD. xcd187
Oct 03, 2007 | Canon S520 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
126 people viewed this question
old marine
old marine
