Won't finish cycle and pump out water - Washing Machines
  • 126 Answers
What brand/ model? There could be a block in your drain pump, or maybe an electrical problem. Can tell better with more info.
Posted on Nov 09, 2010
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
Jun 20, 2012 | Asko W6222 Top Load Washer
Won't finish cycle
If you can't see a clean out drain on the bottom panel pull the panel off (three screws on bottom)...you will see the drain pump unscrew the clean out (get a bucket) these models won't finish a cycle unless ALL the water is out. nine times out of ten this is the problem. Hope this helps.
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
Won't finish the wash cycle and flashes the code F 02
This code means that the machine is not evacuating its water.
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jun 09, 2011 | Kenmore Washing Machines
Won't spin out the water
If your problem is that it won't go into an accelerated spin cycle at the end, check the settings. Most washers just let water drain out the bottom when they have finished cleaning.
May 15, 2011 | Washing Machines
Kenmore Model @16969990 Washing water doesn't pump out, cycle doesn't finish, attemptes to run other cycles default to "normal wash"
The drain cycle does not complete as the drain pump is not working the pump out the water. So unless the drain level comes down to reset the water level controller the program does not progress further.
So check the voltage during the drain cycle if voltage is present then the drain pump is faulty if not the main controller is faulty.
replace accordingly.
Sep 17, 2010 | Kenmore Dishwashers
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
