Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune When not in use for several hours the drum will fill itself almost 1/2 way up the door. You can't hear it so it must trickle in. Also must run another spin cycle most times but not all. Does having the units on a base help this situation?
    Problem Solver:
  • 8 Answers
You most likely have a piece of debris stuck in the water valve, not allowing it to close off completely. Sometimes you can remove the valve and flush it out, which if successful should restore the normal operation of the valve, however, in most cases you will need to replace the valve. This problem occurs from water debris from your fill hoses, so it is recommended to replace the hoses (and screens) at the same time. And, as always, if you attempt to make the repairs yourself, make sure you unplug the washer first :o)
Posted on Jun 22, 2008
    President:
  • 1,294 Answers
Either your inlet valve is clogged or the pressure of your wall faucet is low. Or finally the inlet valve is defective. First try to clean out & ensure that the pressure is good.
Posted on Jun 16, 2008
Water in the drum between washes
On top of the washer is where you ad the soap usually. When you are NOT running the washer, open the lid to the soap dispenser and see if you see any water trickling through it. If that is the case, you need to replace the water fill valve that the hoses are attached too.
Apr 04, 2014 | Maytag Neptune MAH5500B Front Load Washer
Water in the washer.
First I would have posted this in the washer section not the vacuum section. That being said:
This is normal for a maytag Neptune. There is a liquid filled balance ring on the Neptune washer drum. That is the sloshing you are hearing. The smell is from the water trapped between the door seal and drum. You can wipe down this seal with an old cotton towel or sock and then throw it in with your next load. Also, just leave your door open a crack after your loads are done and the water will evaporate and not sit and get moldy.
Jan 26, 2014 | Washing Machines
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
I hope this helps...
Apr 25, 2011 | Maytag Neptune Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer continues filling with water e
Does it fill when the machine is powered down?
If it does then the fill valve is stuck open and needs replacing
If it does not then you need to check the pressure switch and the air bell on the outer drum which probably has a ball of jellyfied soap in it.
If you take the back off you will see a thin plastic or rubber hose going from the bottom of the drum to a small flying saucer type object.
If you pull the hose off the bottom connection and blow into it you should hear a clicking noise from the pressure switch.
If it clicks then clean out the air bell and refit the hose .
If it does not click then get a new pressure switch
A repairman would test it live but that is not recommended for untrained people
Jun 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Feb 02, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer MAH3000AWW
This is out in cyberspace Cant remember what or where. Do a search for "Maytag Neptune shuts off"
Sep 17, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
