Question about Proform Exercise & Fitness
I have a Pro-Form EKG grip pulse model; PCTL53590 and the belt seems to instantaneously stop... for what seems to be a split second every 3 to 10 minutes intervals. I have oiled the belt and adjusted it, but it still seems to have the same problem. What else can I do the fix this problem? Should I replace the belt or the power board?
  • Greg Elliott
    Greg Elliott Apr 08, 2014
    How and where do you apply lubrication to this model?
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Posted on Sep 12, 2009
SOURCE: I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Posted on Dec 30, 2009
SOURCE: need owners manual for pro form 760 ekg treadmill
Email me at bwatts@netcomm-1.com and I'll send you a PDF file of the manual.
Posted on Feb 03, 2010
  • 16 Answers
SOURCE: How to do you adjust the belt on a Pro form crosswalk 380?
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Posted on Feb 20, 2010
FirsLonewolf
  • 186 Answers
SOURCE: Is there a weight limit
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
Posted on Aug 24, 2011
I have a proform 765 ekg and just replaced the motor because the treadmill kept stopping but it still stops and the breaker kicks off and the motor is real hot. any thoughts on why it still stops
LUBE the deck belt and rollers bearing this happen to due the lack of maintenance. see the video attached. Do it with silicone or wax read your manual.
If after you did lube the problem remain, TIME to replace the old board deck belt.
God bless you
Feb 16, 2013 | Proform Quick Burn Pro Treadmill with 12...
Pro-Form EKG 53590
1)Adjust the REED switch, see the diagram, clean it, and tight the plug or connector very weel
2) LUBe the deck belt, this happen because the lack of maintenance every week of use. Use the 100% silicone lube. Maybe you have a WORN deck belt now.
3) LUBE the rollers bearing with wd-40 use small quantity.
4)Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 25, 2012 | Proform Exercise & Fitness
How do I turn on my Pro form 760 ekg .
Dear Sir.
Please turn on the power switch that goes down in the machine is Red switch, most of time there some light of Neon that illuminated when you push to ON. Otherwise reset the button to the side to the power button.
If everything is o.k go inside of the machine and see if the breaker of fuse is tripped or blow, or corrored ( clean but disconnect the power cord): and try again. If not work. You must see if you have power from the outlet wall in your house and reset your breaker.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Proform Treadmill with iFit Live
The pulse reading often displays a low value like 60 even though my pulse is 120 or higher.
Good contact with the grip is essential. Before taking pulse, stop walking and step on side rails and place hands on contacts.
Try gripping the handlebar contacts over the top, with your thumb next to your index finger instead of gripping it with your thumb under the handlebars.
Contact heart rate grips are not intended for continuous reading. Rather, try holding the grips for 10-20 seconds at a time for an accurate reading.
Static electricity can damage the heart rate grip receiver and/or grips and cause either an "HR" or no reading at all.
Oct 16, 2011 | Horizon T91 Treadmill
Is there a weight limit on the Pro-Form 760 EKG treadmill? While I am walking the belt skips and I feel like I am going to fall.
Aug 24, 2011 | Proform 760 CrossTrainer Treadmill
Dec 29, 2009 | Exercise & Fitness
Pro-Form 775 EKG Just stop milddle of running
it seems a speed sensor feedback problem
if competent remove power supply to threadmill ,open covers and locate speed sensor on motor drive unit ,blow dry air using a suitable air compressor or just use a brush to gentle remove any deposits
close covers and retry
Jul 21, 2009 | Nordic Track NordicTrack Treadmill, A2550
Pro-Form XP 550 Troubleshooting
My Proform 550 doess not work the treadmill is not getting any power. Wht might the problem be.
Apr 27, 2009 | Exercise & Fitness
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Exercise & Fitness Logo
450 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
