Question about ViewSonic VX710 17" Flat Panel LCD Monitor
A black vertical line with some green and varied in width began appearing on my screen. It started out small, but has grown in length and width.
5 Suggested Answers
glamaxjoe
  • 56 Answers
SOURCE: a black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Posted on Jan 28, 2008
proton77
  • 1183 Answers
SOURCE: display
HI,
Disconnect the monitor from the computer and check if the vertical line still appears on the screen . If yes the monitor needs to be replaced.
Generally all viewsonic screens come with 3 yr warranty and you can call them up for repairs or replacements .
Thanks
Proton
Posted on Jul 26, 2008
  • 3 Answers
SOURCE: display
time for a new moniter
  • 3940 Answers
SOURCE: Black spot is growing on my LCD Monitor
It is the LCD itself failing, no repair for the LCD itself, the screen will need to be replaced. Likely cheaper to replace the entitr monitor
Posted on Sep 20, 2009
Black lines screen vertical
It sounds to be a COF fault. If you wish to get more details, check the site linked here. Pull up older posts. It has screen-shots to defective plasma and LCD TVs, along with some details to locate the faulty section.
Dec 01, 2013 | Televison & Video
Black and white vertical lines on left sided of screen. Black and white vertical lines vary in width. Left of vertical lines is wrapped video from right side. This is happening on all inputs. I have very...
If its under warranty take it back immediately!!! If not you will need to have the set diagnosed to pinpoint the problem. You could be looking at a faulty t-con/panel connection (easy fix) or a bad t-con board(inexpensive) or a LCD panel(very expensive) failure !
Oct 08, 2013 | Samsung UN60C6300 60 in LCD TV
The picture keeps on changing size.Can I fix this easily?
Hello, I need some more details so I can help, whether the image has grown in height or width? Or that the picture has grown at once, even height and width together? In addition I need the TV model, it says on the sticker at the back of the TV.
Feb 27, 2011 | Sony Televison & Video
Sharp 26"hdtv started with a 1/16" color bar that
If you mean the bar goes top to bottom, there are circuitboards that feed the info in small sections top to bottom. But usually one section will be one inch wide. It can also be the screen panel itself. Try a trusted tv shop
Nov 25, 2010 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
Vertical lines appear on screen...
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
May 16, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Vertical green line on screen
If your set is a plasma, this can be one of two problems : either there is a loose connection (one of many, many connections) between the plasma screen and the driver board, or one of the transistor devices has blown. Try GENTLY applying pressure to the opposite ends of the TV to give it a subtle "twist" (please be careful!). Sometimes moving the set to a different location will produce the same effect. If it's still under warranty, call your dealer. Vertical stripes are a common fault with plasma technology I'm afraid! :-( Next time, go for LCD!
Apr 09, 2007 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
ViewSonic VX710 17" Flat Panel LCD Monitor Logo
48 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
