Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
I think my relief valve broke because my water was turned off because of a leak and when the handyman (not a plumber) fixed the leak, he may have turned the water pressure up too high and had nothing to check it with... I've only had lukewarm water since he left 27 hours ago and discovered water pouring out from the relief drain today. I think it blew right away since I haven't had hot water since he left. I turned off the valve to the water.
    Genius:
  • 1,015 Answers
This is one possible solution. Not knowing the type of plumbing pipes you have or where the leak was makes it hard to give you a solid answer. Some people will open the t&p valve to aid in draining water out of piping to facilitate repairs. There is a small lever in the center of the t&p valve that should be at 90 degree angle to front surface of a valve mounted on side of tank. If it's straight out it is open. Push down on lever to close it. If it was opened and then closed it may not have shut off completly due to mineral build up around valve seat.If it is open then close it and turn water supply back on. If it is closed you can turn water supply on and using wooden hammer handle or other light tool tap directly on center of valve. Do not hit it very hard. If it has been opened and failed to seal you should see a reduction of flow rate fromt&p valve. Either way youshould have t&p valve replaced as it should olny open due to extremely hot water which also will cause increase in pressure. Hope this helps. Thanks.
Posted on Nov 09, 2010
Rheem water heater leaking water from relief valve pipe
the relief valve is replaceable . if it isn't leaking I would not worry about it
Feb 19, 2016 | Rheem Water Heaters
My pressure relief valve keeps blowing more so when it is hot any ideas please
Pressure relief valves open on high temperature as well as high pressure. They do go bad and are replaceable.
Consider calling the plumber. It is not very expensive part and the plumber can change it quickly.
If you just want to do it yourself:
  1. Write down the make and model of the water heater.
  2. Go to a real plumbing store and buy a new one.
  3. Turn off the heat source (the gas or electricity)
  4. Turn off the water inlet and open a hot water valve at any sink to take the pressure off the heater.
  5. Remove the old relief valve. It may take a long handled wrench.
  6. Install the new pressure relief.
  7. Close the sink valve.
  8. Turn on the water and check for leaks.
  9. Turn on the heat source.
Good luck.
Apr 11, 2015 | Water Heaters
Patricia bailey the product I asked question about is a inter therm 40 gal hot water heater model HSE-40F-240S
call a plumber to have the valve replaced is all you can do dear!!!!! to make hotter water you need to turn the thermostats up they are behind metal plates where the elements are .doing so will cost more money on electric bill
Feb 17, 2015 | Water Water Heaters
The water is out flow.After the system runs. It is keep dripping a while then stop. It can be filled up that bucket a day
The water heater is equipped with safety device called a pressure relief valve. This valve is designed to open automatically when water pressure inside the tank becomes too great.
The relief valve should have a lever on the top. Lift it / push down on it briefly and it will allow water in the tank to flow through it (and out the pipe into the bucket). By allowing water to flow, will clear any debris caught between the seat and seal that may be causing the leak. If the valve continues to leak after doing this, the valve should be replaced. In most areas, this type of work is required to be performed by a licensed / qualified plumber.
Feb 20, 2013 | Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    It occasionally leaks water - maybe a quart, leaves a puddle in the middle of the floor and I can see that it came somewhere from the heater, but not where because it is not leaking from anyplace. I have...
    Here are a few tings to look for:
    When COLD WATER comes into the heater, it might cause sweating of the Cold water line, if the humidity is high in the house? This is usually in summer time only-- when the humidity inside the house is higher..
    Another possible place, is the relief valve:
    If you have a check valve or two in the system, that ends up trapping all the COLD water in the tank, as it goes thru its heating cycle, -- the Cold water expands, and has to be relieved-- Thus the relief valve will spit out a puddle of water keeping the pressure at a safe level.
    (However-- usually the system has a drop pipe coming out of the relief valve-- so likely you would have said that the puddle was at the bottom of the drop pipe-- and you probably would have suspected it..)
    However-- Do these suggestions give you some ideas of where the water puddle is coming from ?
    Tell us more-
    Mack B
    Jan 17, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    My water heater is leaking water at the foot stand, should I shut the heater off and do I need a new water heater?
    Make sure that the water is not coming from the drain valve, the relief valve or some top fitting and running down the insulation inside the visible outer skin of the heater.
    If it is truly a bottom leak, which is common when the heater fails, if the leak is getting on the flame or pilot, you should shut it off. If the water creates an unacceptable situation, for example, leaking on a finished floor, shut the water off.
    If the water is leaking slowly and the flame is not being wet down, you can call a plumber and use the tank on an emergency basis.
    Dec 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Water leaking from the bottom of the big PVC pipe parallel to the water heater
    What is the leaking pvc pipe connected to? The T & P valve on the side (or top) of the tank? Or is it an incoming cold or outgoing hot water line? If you have just lit the water heater, the T & P valve may drip, but only for a little while and it will stop. The T & P (temperature and pressure relief) valve may be bad and need replaced. Turn off the incoming cold water valve and turn the gas valve to off position. Then drain the water heater using the T & P valve, it will stop draining when the water level is just below it. Remove the T&P valve and replace with new one. Use thread sealing tape on threads. Or call a plumber if not sure.
    May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Relief blowing out hot water every hour or so. Controller? Set at about 125.
    try replacing the pressure relief valve to do so turn off water to heater and turn off power or gas which ever you have drain water from heater. then using pipe wrench remove old relief valve. when installing new valve use teflon tape on threads to prevent leaks then thread by hand back into water heater and use pipe wrench to snug dont over tighten turn water back on after full and no leaks turn power back on or relite piolit
    Nov 24, 2009 | Water Heaters
    Relief valve constantly releasing water.
    lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
    Jan 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
    124 people viewed this question
    Top Rheem Water Heaters Experts
    Donni Steen
    gizmonix
    Level 1 Expert
    Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
