Question about GE Spectra JBP78 Electric Kitchen Range
The self cleaning oven cuts off before cleaning cycle. I push the self clean button after locking the oven door: the bell dings several times and the self clean cycle cuts off. This is a new stove--what am I doing wrong?
  • GE Master
  • 43,501 Answers
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Nov 09, 2010
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Gas range oven door with not open
    Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
    Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
    How to use the self clean feature for a Frigidaire FES 355 ASF
    Hi Anonymous, this is AP!
    I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
    Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
    In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
    Best of luck,
    Apr 03, 2014 | Frigidaire FES355 Electric Kitchen Range
    We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
  • 4
  • Nov 18, 2012 | Ovens
    Cannot unlock oven door
  • Here it is!
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do I start the self cleaning? I hit clean and it does not start
    On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
    Aug 29, 2011 | GE JKP45 Electric Double Oven
    How do i unlock a de dietrich oven?
    In order to unlock the oven you need to perform the following:
    Jun 25, 2011 | De Dietrich Ovens
    Gerangeoven door won't open
    Is it in time bake?
    Oct 04, 2009 | GE Ovens
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Oven door won't unlock
    I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
    Feb 16, 2008 | Kitchen Ranges
    GE Spectra JBP78 Electric Kitchen Range Logo
    212 people viewed this question
    Top Kitchen Ranges Experts
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Sal De
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
