Question about Kenmore Sewing Machines
Thread bunches bottom of material,not the bobbin thread
  • c_lou_b Nov 10, 2010
    adjusted the thread tension and the bobbin thread,it doesn,t seem to use any of the bobbin thread,can only go a couple stitches and its the top thread that bunches...
  • 2,299 Answers
Adjust the upper thread tension on the dial. Turn the thread tension to a higher number. If that doesn't work, then adjust the pressure foot pressure.
Posted on Nov 09, 2010
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Bobbin thread bunches up under material
make sure that the bobbin carrier is fixed in properly
make the needle thread tension a lot tighter
Jun 23, 2016 | Sewing Machines
Can't get Juki tension right
which tension is wrong
if thread is bunching up under material increase the tension of the needle thread if the bottom thread is loose then increase the bobbin thread tension
each thread result for above or below material will indicate which thread to alter the tension on
Jul 02, 2014 | Juki Sewing Machines
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
Help problems with Bobbin and tread
I found that if the bobbin is not threaded correctly or if the upper thread is not adjusted properly, it will bunch on the bottom. Also, if the stabilizer is not firm enough for the material it will bunch.
Oct 11, 2008 | Husqvarna Viking 1
The bobbin thread is loose and bunches up under the material i have a model 1030 and i dont remember where the tenson is
It is the dial to the right of the take up arm on top. If you go all the way to 10 and nothing happens then you'll need to take it to your nearest technician or Bernina dealership. Also its possible you may have put your bobbin in the bobbincase the wrong way. After putting the bobbin in the case and pulling the thread the bobbin should turn clockwise.
Good luck.
Nov 27, 2007 | Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
