Question about Toshiba Televison & Video
Not all the buttons work when you press them or they have to be pressed extremely hard
    Genius:
  • 1,112 Answers
Hi:
This is due to dirty contact pads inside the remote, you can open the remote and clean the main board contacts and the keypad with some achohol.
Posted on Nov 09, 2010
There are no screws because it is a snap-on. To open the remote control, you will need a slotted screw driver (use a smaller one, like 3/16" x 3") to pry it open. Start prying at the bottom of the remote, near the battery compartment and then the edges. Use delicate force and try a small step at a time. Once you have pryed open the bottom end, follow the edge on the spot where it is opened and start prying the yet opened edge. Insert the blade of the screw driver the slot, grip the screw driver tight and slowly turn clockwise and counterclockwise repeatedly. Try not to separate the cover by hands. You should use the screw driver to pry open it. It took me about 5 minutes or so to open mine. After it is open, check the circuit board surface for oily residue. Try not to touch any IC component with your hands. Don't remove the circuit board, just hold the edges with your hand. There were some oily spots on the numbers' contacts, so I cleaned the circuit board contacts with a lightly damped paper towel. I also cleaned the rubber pad with a sponge and soap and dried it with paper towel before putting it back. After about 15 minutes of work, the remote control came back to life like new.
Posted on Jan 02, 2012
3 Suggested Answers
SOURCE: NEED TO PRESS REALLY HARD TO INCREASE VOLUME. EVERYTHING ELSE WORKS FINE
as time goes buy more of the keys will fail to work, pressing hard on the keys may do some damage to the circuit board inside. you need to remove the batteries any and small screws you can see then pry the two haves apart remove any screws that hold the circuit board to the top half and remove the circuit board to expose the bottom of the key pad you will see a black conductor painted on the bottom of each key button, use a Q-tip dipped in alcohol to clean the black conductor on all the keys then do the same thing to the contact points on the circuit board then rub a pencil eraser over the same contact points on the cicuit board and reclean with alcohol again.
This should fix the problem but it will happen again, and at some point even this won't fix the problem and logitech won't let you buy a new key pad, and that is the point I am at now and for that reason I won't buy another remote from them, I expect more than four years out of this product good luck.
Posted on Jan 12, 2008
techman007
  • 1112 Answers
SOURCE: you have to press the buttons extremely hard
Hi:
This is due to poor contacts inside the remote, if the remote is old then the contact pads may be worn, if it is fairly new then you may of wasted something on the remote and the contacts needs cleaning.. If you open the remote and remove the main board and the keypad clean the tracings on the remote with some achohol also the keypad also..
How do i fix a button that is hard to press on my comcast remote
Call have them send you a new remote. They dont charge to replace remotes
Apr 17, 2015 | Comcast Custom DVR 3 Device Universal...
How do I fix my Nintendo 3Ds (Non-XL) Broken A button?
Everything comes to a point where it wears out my friend. No easy fix on this one. Good Luck
Nov 28, 2014 | Nintendo 3ds Handheld Game Console- Cosmo...
My on / off button will only work pressed in extremely hard
more of a mechanical issue already. if it is within warranty, request a replacemen from Dell
Mar 13, 2011 | Dell E198FP 19" LCD Monitor
Need to reload program to operate Hard drive
if you mean operating system program
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 11, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
How do i hard reset the htc p4600?
This will wipe all the storage (not the sd card) and your device will be reset to default settings.
Hard reset (option 1)
  1. Pull out the stylus.
  2. With the device turned on, press and hold the VOLUME DOWN and CENTER buttons, then press the RESET button with the stylus tip.
  3. Continue pressing the RESET, VOLUME DOWN and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel.
Hard reset (option 2)
You can also use Clear Storage to reset your device back to factory default settings.
  1. On the ?TouchFlo3D Home screen, slide to the Settings tab and then tap All Settings or goto Start and press Settings.
  2. On the System tab, tap Clear Storage.
  3. Enter “1234” and then tap Yes.
Hard reset (option 3)
  2. Turn device OFF.
  3. While pressing the CENTER button, turn the phone on with the POWER button.
  4. Continue pressing the CENTER button until you see this message on the screen:
This works on at least some Verizon CDMA phones on which option 1 will not work.
Hard reset (option 4)
  2. With the device turned off, press and hold the VOLUME DOWN and CENTER buttons, then press and hold the POWER button.
  3. Continue pressing the POWER, VOLUME DOWN, and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel. (works with Alltel touch pro)
Sep 29, 2009 | HTC Touch Diamond Smartphone
Ps2 controller dual shock does not work properly with nascar 2009
it is in the nature of the game.... some games requires a hard pushing button to activate,,, for example the metal gear solid snake,... light press will aim the gun and pressing it hard makes the trigger and go for the fire...
Feb 12, 2009 | Sony PlayStation 2 (PS2) Console
The number 1 button will not work unless extreme force is used
This is a very common problem with the KX-TGA400B and KX-TGA200B handsets. You need to replace the keypad or send it out for repair. Google "KX-TGA400B improved rubber keypad". Do not use the original factory keypad, the contacts are to small.
Dec 15, 2008 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
Slow Responses
Do a backup with PIM Backup and them hard reset the phone (Factory default)
To hard reset the wing: Hold both soft keys down while hitting the reset button with your stylus (the little hole on the side). Should bring up a black screen with some text. Press "send" key to finish process.
*Note it takes a couple of tries to get all of the buttons pressed together. May not work first try.
Aug 14, 2008 | T-Mobile Wing™ Smartphone
Funny Keyboard
your layout change
Mar 21, 2008 | Acer NSK8458AN Keyboard
Televison & Video Logo
1,918 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
