Question about Goodman CKL36AR36 Air Conditioner
I have a goodman aruf 036-00a-1. When I turn the heater on for the first time each season it smells like a burning dog. What can I do?
  • 132 Answers
All heaters smell that way after a long time of not useing it, it's the lint and hair ,dust built up in the unit,clowny daggers
Posted on Nov 09, 2010
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
Goodman ARUF 030-00a-1 leaking freon
spray with soap bubble solution let sit hour then check
Feb 25, 2013 | Goodman CKL36AR36 Air Conditioner
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
I have a blueflame probane heater ventless and when burning it has a slight smell. Is that normal for this ventless heater.
It depends on what it smells like. Initially, when the unit is installed it should be burned on HIGH for 45 minutes to an hour. Doings that, burns off all the oils and seasons the heater. Sort of like seasoning a cast iron skillet. After that, the newness odors should be gone. It's normal to get a whiff of gas when the burner lights or turns off. It should dissipate rather quickly.
Although Vent-free (ventless) heaters are very safe to use and are 99.5% efficient, their one drawback is that pick up strong household odors, like strong cleaning products, carpet shampoos, new paint or stain odors, strong cooking odors, etc and make them worse. That's why it's always best not to use the heater during or after painting, for at least 2 weeks. Although your nose may not detect the paint odor, the heater can and will make it worse. Also, always use your range's exhaust hood when cooking. Hopefully, it's the vented type and not one of do nothing recycling hoods.
Also, thoroughly cleaning the heater inside and out , at least once a season, will go along way in reducing odors and maintaining the longevity of your heater.
One other caution, do not burn scented candles and operate the heater at the same time. Scented candles soot anyway, but adding the warm moist, comfortable heat from the vent-free heater, will cause them to soot 50 times worse. Trust me, it's not the heater, it's the scented candles sooting.
Hope this helped explain some of the things that you asked about and more. If I can be of further help, please ask me through the Leave a Comment link.
Apr 22, 2011 | Procom MN300HGB Heater
My Heater goodman. Problems is smell like carbon monoxide emissions. what can i do.
Sorry to read about your problem, I hope this helps you out.
well first you cant smell carbon monoxide, but i suggest you contact a service person, that has the proper equipment, to tell if you have a carbon monoxide issue....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Goodman GMS90703BXA Heater
Ihave a Goodman GUS075-3 model. Turned the heat on for the first time this year. After abt 5 mins. running it started to smell like it was on fire, the breaker shut off. Now,the pilot keeps going out and...
I would suspect that your fan motor burned out. What I would suggest is wait about 1/2 hour with thermostat turned down to lowest setting where it is not trying to turn furnace on. I would then turn thermostat back up to call for heat and see what happens. Most electric motors have a thermal overload on them and if its on motor will not run until it cools back down. Even if this works I would recommend that you have motor replaced and clean blower. Hope this helps. Thanks
Nov 04, 2010 | Goodman Heating & Cooling
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
Burning Smell from Old Baseboard Heather All of a Sudden
If it was the first time started this season, then it was dust buildup burning off. If burning smell continues, call for service.
Dec 15, 2009 | Cadet Manufacturing 4F1000-8A Electric...
Furnance does not come on (first time to turn it on this season). It has power and blower/motor area heats up(I can smell the dust burning) but nothing blows out though the fan works.
You have a fan switch for the blower that's probably bad.
It only allows the blower to start and stop at a certain set temperature.
Nov 23, 2009 | Heating & Cooling
Heater problem model PHK 080-1
THE BURNING SMELL IS NORMAL. BEFORE HEATING SEASON OPEN ALL DOORS AND TURN THE HEAT UP AND LET RUN TILL ALL DUST IS BURNT OFF. IF BLOWER IS NOT COMMING ON NOW. THERE ARE 2 TIME DELAY RELAYS, AND ANOTHER RELAY FOR "FAN ONLY OPERATION". ALWAYS MAKE SURE THEY ARE NOT THE PROBLEM BEFORE REPLACING AN EXPENSIVE MOTOR.
Feb 07, 2007 | Goodman PHKJ060-1 Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
271 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
