Question about Canon PIXMA iP1200 Photo Printer
Damage driver< cd driver
Hello ,i have a problem while connecting my kodak scanner i780 ,there is a message&lt;&lt;unable to start scanner,please read the kds.log for more information&gt;&gt; so plz help me so
Did you use the installation software CD-rom before running it on your new computer? Most scanners comes with an installation CD that you have to install before using it. You may also have to restart your computer before using it after the installation. Good luck.
Nov 06, 2014 | Kodak Scanners Kodak I600/I700/I800 Series...
My acer 4715z freeze if ipress ctrl keys
Daniela,I assumed your recent driver update missmatch. any behaviour un-normal keys function may caused by missmatch drivers. AHCI_Intel_v.7.5.0.1017_XPx86.zip << for updated driver acer aspire 4715z windows vista & Xp
akee_akee@live.com
Aug 16, 2011 | Acer Computers & Internet
I have a laptop hp compaq 2230s, which does not want to connet to the internet. the message is saying that i have only a local area connection and therefore does not receive data from the net, even when...
For Windows XP you may re-install chipset driver, wrong driver may cause ethernet driver missed driver too
2006-03-24 , Version:7.2.2.1006 A, 1.07M <<< Chipset compaq presario v6000t ( Intel ICH7 ).
For Windows Vista : open device manager >>> update driver chipset > via internet or you can ask for the driver by personal.
Aug 15, 2011 | HP Compaq Presario V6000T Notebook
<object style="height: 390px; width:
Hi wait a moment pls your request is been proceeding..
Jan 17, 2011 | Play Inc USB Sound Box, play MP3 and CD...
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
<b>Ada YanG PuNYA CD KeY CyBErLInK PoWeR dVD
Cyberlink PowerDVD 8.0 (130033) S/N: AM273F93212G6465 winzip 12 (177569) Name: Franky Quadros S/N: Pro S/N:W14CM-DKD5W-C7YAV-Q4N6Z-MH82V-X5FGQ STD Winzip 12 S/N :HA4QQ-7FUUD-YVLG0-25UW3-HRGGM-X5FGQ
Dec 11, 2010 | WinZip 12.0 - Windows for PC
Diagnostic Report (1.9.0027.0): ----------------------------------------- Windows Validation Data--> Validation
> Blocked VLK
> Windows Product Key: *****-*****-3R89F-D2KXW-VPK3J
> Windows License Type: Volume
> Windows OS version: 5.1.2600.2.00010100.3.0.
Where did you obtain the CD-ROM that you used to install Windows,
using that Product Key?
A "VLK' is a "volume license key" -- when some organization purchases a specific number
of licenses to install Windows XP, Microsoft issues a "volume" license-key,
so that all (up to the number of licenses they purchased) computers in that organization
can use the _same_ license-key.
If Microsoft detects that the product-key is being used *OUTSIDE* of that specific organization,
then Microsoft will *BLOCK* all attempts to "activate" Windows that cite that product-key.
I did a Google-search for '3R89F-D2KXW-VPK3J' and Google reported 37 THOUSAND web-pages that contain that string. That is a *DEFINITE* sign that the VLK has been "leaked" onto the Internet.
So, you are trying to use a "non-genuine" copy of Microsoft Windows XP.
Thus, you are a "SOFTWARE PIRATE".
Purchase a *GENUINE* copy of Windows XP (or Vista or 7) and install it,
and throw away your "pirated" copy of Windows.
Dec 10, 2010 | Computers & Internet
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Feb 14, 2010 | HP Compaq nx6110 PC Laptop
Sony DVD RW (Model DRU-840A) Drivers
Hi, here are the firmware/drivers/utilities to your sony dvd drive.
>>>>Link<<<<
Hope This Helps
Muzzi_123
Jul 16, 2009 | Sony DRU840A DVD-RAM Burner
Canon PIXMA iP1200 Photo Printer Logo
18 people viewed this question
old marine
old marine
