Question about Lexmark X5470 All-In-One InkJet Printer
Entire sheet of paper disappeared inside printer. Can't see paper at insert slot or exit. Printer has stopped. How do I open printer to retrieve paper?
    Genius:
  • 1,112 Answers
Hi:
Usually there is a back paper trap door you can access, there is sometimes a knob you have to turn to open it. Also there may be something that is causing the paper to hang up inside a printer, I suggest you turn the printer upside down and see if any foreign object falls out before reinserting paper again, usually a paper clip will be found or if you have children then who know what will fall out, they like to things inside printers. Especially coins..
Posted on Nov 09, 2010
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
LexMark 5400 Series All-In-One Printer
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
Feb 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Paper jam
Also see this:
    Note:
Top
Top
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper Jam at exit
This happened with an old HP Laserjet 1100A of mine.
I had apparently dropped a screw in the paper-out slot and it was jamming the paper on just one spot.
As you know, the entire sheet is connected, so It is most likely a similar situation in which a previous jam has left a small wad of paper under one of the rollers, and this is preventing the paper from exiting the slot.
Best bet, print something and see where the paper is scrunching up. This is most likely the roller that has the paper stuck under it. Remove the toner block and blast some compressed air into the spot the jam is most likely originating and see if anything else flys out.
Also, if that does not work, you might try manually rotating the rollers backwards, which will often eject the lodged paper chunk.
Note- Please be careful inside the printer! Do not touch the bright green drum, or anything that dosen't look like it is rubber and rolls paper around!
It is very easy to mess things up in there ;)
Sep 28, 2008 | Samsung CLP 300 Laser Printer
Paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Mar 21, 2008 | Samsung ML-2550 Laser Printer
Dell 924 Paper Jam
are you getting a jam error?
If not load a letter sized 8.5 x 11" inch sheet of paper or carstock in printer print somthing let paper get about halfway down in printer then uplug printer and plug it back up as it comes back on it will usally rotate rollers forcing the paper out if you used card stock this should be stiff enough to force the smaller paper out
Dec 07, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
