Question about Chamberlain 750CB Single-Button Remote Control
The remote was not working. Changed the battery and still was not working. I realized that the switch code was changed when changing the battery. I than went to the main unit in gargage and couldnt see the code, so desided to push all the switchs down the main unit and on the remote figuring that they would match and the remote would work. Still no luck.. Is there something I am doing wrong. If all switches are matchng why is the remote still not working. Please help. Let me know if I need a certain code
2 Suggested Answers
  • 59 Answers
SOURCE: Black and Decker garage opener not working,
Here is a link to the instruction manual and instruction video.
Chamberlain Clicker Universal Remote Control KLIK1U
Posted on Jan 08, 2011
How do you replace the censor in a hampton bay ceiling fixture
Apr 05, 2013 | Hampton Bay Dryers
Changed the batteries and it just stopped working ,I get nothing
If you have changed the batteries of the remote control, all setup codes previously it have, been resetted. You have to setup the remote to your TV, by it code, once again.
Jun 20, 2012 | Hitachi CLU-4324UG Remote Control
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
Receiver was beeping all the time. I changed batteries in receiver, and now remote does not control fireplace. Remote appears to be working fine. If I move switch to on instead of remote on receiver, it...
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Feb 03, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech model no. sky-3001 changed batteries in remote and the transciever now i get nothing you can manually get fireplace to turn on using the transciever but when you switch it to remote and try to use...
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Dec 18, 2010 | Skytech 3301 Thermostatic Gas Fireplace &...
Remote won't work since I changed the code on the garage door opener
thats because you didn't recode the remote to the garage door or you have not recoded it correctly. double check the remotes settings (if it can be changed) to ensure it matches the door opener. Now, if you cannot see any method of changing the remote to suit the main unit, it may be that the remote is factory coded or that it is coded by Soldering links on the circuit board. Carefully disassemble the remote to have a look if it does not have a small bank of switches in the battery compartment. If the switches are there, check the coding is the same as the main unit, if the switches are not there, disassemble and check for solder links on the circuit board. If you are not confident with using a soldering iron, take the remote to someone who is.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
My remote is not working. On the back it says 6.2 IR/UHF PRO Canada: 1707A-DKNFSK03 139779 It used to work fine, then I had to change the batteries and it no longer works. The lights work but nothing...
The switch that selects what type of remote style (UHF or IR) is probably the culpret.
pull the battery cover and take out the blue tab
Play with the switch unitl it works and put the tab back in (the tab is supposed to select the right value for you but it may not be properly aligned.
i was about to toss mine but this worked.
Dec 24, 2009 | Bell SH50102 Remote Control
Remote not working at all
Check the fan and the remote to see the code switches are same. Sometimes depending on the age and humidity you may have to slide the switches back and forth to clean the contacts. Did it ever work? Are the batteries in the proper polarities? The fan and remote have to have the same numbers picked to operate properly.
Nov 16, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Chamberlain 750CB Single-Button Remote Control Logo
21 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
