Question about Sharp AR-M355N Copier
I have a sharp AR-M355N machine and I keep getting error code F2-00, what does this mean, is there a specific fix for it
  • 4 Answers
This code is Toner Control Sensor open/trouble.
Check connection of the toner control sensor.
Check connection of connector and harness to the main PWB.
Check for disconnection of harness.
If all is fine, replace the sensor.
Posted on Nov 11, 2010
How do I fix the copier if it says call for service?
Hi
You don't mention any error code that may shown and which would identify where the fault is. A full list of error codes can be found here:
Error Codes Sharp ARM355
and from here you can also get a pdf format service manual for this model which in combination with the error code explanation may enable you to fix your machine. On the error code page you can also change the model of your machine if you need to by using the drop down menu in the centre of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Sharp BR AR-M355N/455N - 1-DRUM
Call for service. Code: L4-02
You need to make sure the machine is in Copy Mode then hit
Pound, Star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jun 25, 2014 | Sharp AR-M355N Copier
How do I set up an address to the frequently used addresses tabs on sharp ar m355n?
on the web page(accessed by typing the machines' IP address into a web browser)
click destination, the username is admin, and the password is Sharp
then put a check next to the person's name, and click edit
then check the "Frequently used" box on the page and click submit.
Jun 19, 2014 | Sharp AR-M355N Copier
Sharp m355n error code L3-00
L3-00 means that the scanner (the light under the glass) isnt moving correctly. You can reset it by pressing clear, interupt,0, interupt, 14,1, start button. Good luck
Jan 23, 2014 | Sharp AR-M355N Grayscale Copier
Ar M55on Keeps turning itself off and on
Machine is trying to load toner .just let it continue until it gives
an error code otherwise ..
Dec 03, 2013 | Sharp AR-M355N Grayscale Copier
Error code e7 02 mean
check wiring at the scanner
May 27, 2013 | Sharp AR-M355N Copier
Error code L4-02, what is the error?
In the Sharps, a L4 error is some kind of motor error. Not sure about L4-02 on the 355.
Aug 25, 2010 | Sharp AR-M355N Copier
I have a AR M355N and it gives me "finisher out of service." Do I need all the trays installed to clear this?
Maybe? Most likely the problem could be with the stapler unit not finding HP. Did you have a error code before the finsher could not be used?
May 27, 2010 | Sharp AR-M355N Copier
Error code E7-02, what does it mean? how to fix it? Sharp Copier AR-M355U
That is a problem with the laser.
There is a glass down in the drum/toner area that you can remove and clean .
You can also try, pressing p*c*, which is #*C* and press 14 first and follow the fault clear procedure, then 15, 16 and 17, press clear a couple of times and the machine will reset. If that does not resolve the problem, there is a motor in the laser unit that has a motor with small mirrors attached. That is the most likely part failure.
Mar 09, 2010 | Sharp AR-M355N Copier
Error Code E7-03
THAT IS LASER PROBLEM.JUST CHECK LASER UNIT .IT IS SENSETIVE UNIT.CALL A ENGINEER TO SOLVE THIS .ITS BETTER.BY MIAN AKHLAQ
Nov 01, 2008 | Sharp AR-M355N Copier
Sharp AR-M355N Copier Logo
372 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
