Question about Refrigerators
I need to replace the water dispenser on a Regrigerator but I can't find any way to remove the door cover or the water dispenser cover from the front. How do I get to the water dispenser?
  • 4,059 Answers
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Nov 09, 2010
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
I have a kenmore coldspot model 10656356500. water/ice dispenser not dispensing water. check line , not frozen. need to remove trim and cover on door to check switch. can not get cover off. need help on...
It is possible that the switch at the dispenser switch is defective but not as likely as the water control valve=> W10408179 found on the rear of your refrigerator. The coil may be burned out or weaking and not allowing water to flow when you press your cup to dispense. Have someone ohm both coils and the resistance should be close to the same. Applying 120 volts to the water dispenser side of the dual valve should cause water to flow. They just sometimes burn out and yes the dispenser components wearout too.Large View=> 10656356500_Dispenser_Parts To remove the Face of the dispenser follow the instructions in red at bottom of photo=> HERE Use care and mark and remember were the screws go when you replace the facade. If you have any other questions I will be here, Thanks, Sea Breeze
Jul 24, 2011 | Refrigerators
I have no manual and I want to make ice cubes and be able to drink filtered water. I do not get any ice cubes when I switch the button on in the left rear. I am not getting water. I have removed, to...
1. Keep freezer temp setting @ 5 degree.2. Check water supply with full pressure (Back of regrigerator) 3. Confirm shut off arm is not struck due to huge cubes stored in bucket. If so, please remove ice cubes.4. Check solenoid valve which allows water flow whenever required to ice maker is working.
Please follow the steps also given hereunder.
Close the freezer door completely. The dispenser will not work while thedoor is open. Place the ice bin in the proper position. Avoid placing ice inthe bin that was not made by the ice maker. The cubes may jam in the deliverychute. If ice is jammed in the delivery chute, remove it with a plastic utensil.Discard the ice in the bin and wash it if ice has melted around the auger. Drythoroughly before replacing it. Wait three minutes if the dispenser stopsdispensing ice after the arm has been held in for a long time. The dispensermotor will reset and will begin to dispense ice again.
Thanks
Jan 29, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
Our 2 door water dispensor not working. ice coming through o.k.
I followed a suggestion from one of your customers and it worked!
JKP
Jan 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
In door ice dispenser
Remove the top freezer door hinge cover , and disconnect the plug there . This will remove the power to the door . Inside the lower part of the dispensor cover , inside the dispensor area , between the grill and the actual dispensor bottom , use a small screwdriver in the crease , and push down and inward carefully , to release the 2 plastic clips , mounted on the bottom of the dispensor cover . 1 clip on each side at the bottom . Then lift the cover straight up ( not outward ) , to release the top plastic clips Then unplug the receptical to the dispensor cover . You should see 4 screws holding the dispensor caseing , which will need to be removed , for access to the controls .
Oct 25, 2009 | Refrigerators
KitchenAid KSRG25FKSS16 Side by Side will not make ice
First I would check for obstructions in the line from the water inlet valve to the tray assembly. If thats good check the valve it self. This is a double valve, it supplies water to the door and it supplies water to the ice maker. Check and compare both coils. They should be around 300 Ohms. If not, replace it. Try Partselect.com
Oct 10, 2009 | KitchenAid Refrigerators
The water is not working
Put a space heater in front of the door for an hour. If that is not it check the solenoid valve for obstruction.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Contents of crisper drawers are frozen
may be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
