Question about Garden
I have honda gcv160 5.5 pressure washer, after sitting over winter, I went to use it, and I can't even pull the cord to try and start it. What are any reccomendations as to what I can do to fix this?
My power washer started doing that after the pull-cord mechanism broke.
I took off the hoses to make sure there was no back-pressure caused by the pump.
And pull rope was still frozen.
We took off the pull rope cover on top of the machine.
The cover came off easy.
After that we lifted out the spring-pulley where the rope is attached the spring unwound and we couldn't get it back together so I bought another one.
We should not have lifted it out ... we should have tried to get it to move first without lifting it up.
In any case the washer worked fine after the replacement.
When you store a power washer, be sure to drain the water and disconnect the hoses.
Don't leave any gasoline in the engine or it will gum up the carburetor.
Never turn a gasoline engine on its side or upside down or the oil will run into carburetor, and carburetor will need work.
Posted on Nov 09, 2010
Black max 3000 honda pressure washer won't start
You need two things for the engine to start, spark and fuel. Pull the plug, hold it close to the engine and pull the starter cord- check for spark. If there is spark (most likely there wil be spark), then it is a fuel problem. Try a little startiing fluid into the breather and see if that gets it to start. If that works, then the problem is in the carbureator - it probably needs to be rebuilt if the engine has been sitting for a while.
Apr 13, 2014 | Honda Black Max 3000 Psi Pressure Washer
Tip
Pressure washer
I have repaired hundreds of pressure washer pumps.( Winterizing)Always tip up pressure washer to get out most of the water.Then purchase pump armor.This is like anti-freeze.If not available use light weight oil.(mineral oil is o.k.Tip back washer and pour a little in.Then pull motor start cord a couple of times and your safe for the winter.
on Oct 17, 2010 | Garden
Crank pull cord doesn't pull out on honda pressure washer.. The machine is only 3 months old
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Dec 02, 2010 | Honda Pressure Washer PSI 3000
I tried to start the pressure washer by lulling the cord, there was sharp popping noise, and the engine would not crank to start. It is a Honda K. washer. What went wrong? Pls advise, thanks.
Make sure your oil level is correct and not overfull. If ok, pull the sparkplug out. Then, pull the starter rope to see if the engine spins freely. If it does, pull it 4-5 more times to clear the cylinder of oil or gas. Put the plug back in and try it again.
However, if the rope fails to pull freely, you either have a locked engine or pump. You will have to seperate the pump from the engine to determine which is locked up.
Aug 02, 2010 | Honda Garden
I can not pull the string to start the engine of power washer
Try removing the spark plug then pulling the cord! If the cord pulls then you cycle the engine a couple of time to see if fuel is coming out of the spark plug hole! If no fuel present replace spark plug and try starting the engine. always have water running through your washer before you attemp to start!
Jul 17, 2010 | Honda Pressure Washer PSI 3000
Starter cord wont pull
Try removing your spark plug, you could have fuel on top of the piston or even "vapor lock". If that doesnt work try squeezing the trigger of gun/wand as you pull.
May 31, 2010 | Honda Pressure Washer PSI 3000
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Mar 17, 2009 | Campbell Hausfeld Garden
Garden Logo
519 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
