Question about HP Officejet J4680 InkJet Printer
Incompatible cartridge? - HP Officejet J4680 InkJet Printer
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
"Incompatible Cartridge" error
Try uninstalling printer, reboot computer then reinstall printer drivers. do not accept HP updates as they block non HP consumables. Update manually if needs must.
May 09, 2013 | HP Officejet 6310 All-In-One InkJet...
My new hp61xl cartridge doesn't work - I get an "incompatible ink cartridge" display
please open the cartridge and check and clean for cotton and re install cartridge insallah solve the problem
May 09, 2012 | HP LaserJet 3050 All-In-One Printer
HP Officejet 4500 Incompatible Black Cartridge
I have an HP officejet 4500. When I replace cartridge the printer reported Incompatible print cartridge. How can I get the printer to accept the cartridge and start printing again? The color cartridge is original to the printer and the black cartridge is the "new" one.
Feb 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Message says Wrong Cartridge , Display screen flashes with Wrong Cartridge or Insert Cartridge , but we have changed nothing on the unit at all.
This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Dec 07, 2009 | Office Equipment & Supplies
"incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
EPSON STYLUS C90 CISS INCOMPATIBLE CARTRIDGE!!
The cartridge may be defective, as I seen this numerous times, try buying another cartridge from a diffrent retailer and make sure the tape is removed before installing the cartridge.
If this works, you can contact Epson if it is there OEM cartridge that is defective for a refund or replacement.
Good Luck.
Feb 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
Incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
Dec 25, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP Officejet J4680 InkJet Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
