Question about Jenn-Air JCD2389G Side by Side Refrigerator
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
  • 51 Answers
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Posted on Feb 02, 2011
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Jenn aire refrigerator not completely freezing ice cubes
Increase the inside coldness by rotating the termostat switch nob to a higher number position.
Oct 03, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Locked freezer
Press and hold the lock button for at least 3 seconds
Feb 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-air JRSD 226 side by side Fridge
Check to see if there is frost on the rear wall o f the freezer wall. If so, the units cooling coils (behind the frost) may be covered with ice. Defrosting is necessary. The refrigerator may not be defrosting at regular intervals a required. Standing open for a couple of days should defrost it but it will still be necessary to find out why it frosted over. There is a defrost control that automatically melts ice from the cooling coils on a regular basis. Maybe this control is not functioning.
Aug 29, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
302 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
