Question about Freezers
Hole in freezer
Unfortunately a hole was created in the freezer and there was gas leakage. i closed the hole.. Now exactly what should i do. waiting for your reply..
  • 828 Answers
Time to get a new one. I take it you defrosted using a sharp object. Not the thing to do. Defrosting can be done with a simple device such as a hair dryer and do the system no harm.
Posted on Jun 18, 2008
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
Everything at the top of my freezer has defrosted. The bottom is still frozen.
The freon gas is not circulating properly and there is a leakage in the cooling pipes. You have to call a technician and have the leakage located. Could be that gas is not sufficient.
May 14, 2011 | Freezers
Fridge freezer freezer ok fridge warm willnot chill
dear sir/madam
i think there can be possible low gas problem it,s naturally if in your freezer there is low gas then it,s coil get warm. it,s coz of low gas so please contact to your service technician for find out leakage and brazing it and then refill the gas. i hope after that your freezer will work well.
hope answer the question
thank you
please vote!
Aug 30, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer is working but fridge is not.any idea of the problem?
dear sir/madam
i think in your freezer there is low gas problem please contact to maintenance personnel for find out the leakage and brazing it then refill the gas
hope answer the question.
thank you
please vote!
Aug 23, 2010 | Belling Freezers
The freezer does not cool
dear sir /madam
please check first your fridge,s compressor is working or not if it,s working and not getting cold then it can be low gas problem so please contact to your freezer maintenance personnel for further action i mean find out leakage and brazing that after fill refrigerant gas , after that i hope your freezer will work good .
thank you
please vote!
Aug 12, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
No cooling. hot side and top.
dear sir/madam
i think there is low gas problem in your freezer so please contact to your freezer maintenance personnel for further action i mean find out leakage and make brazing it and then refill gas.
thank you
hope answer th question
please vote!
Aug 10, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not getting cold enough
dear sir/madam
make sure first your freezer,s condenser fan motor is working if it,s working and its not getting good cool then it can be low gas problem so please contact to your maintenance personnel for find out the leakage and make it brazing and after refill refrigerant gas.
thank you
please vote!
Aug 09, 2010 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Freezer problem
Dear it depends upon the temperature settled, but i think that the problem is with the gas leakage in your freezer, thats why it cooling is geting week, so , it is better to call a mechanic to check it properly.
Best regards
May 25, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
73 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
