My monitor appears only input not supported acer model x153w
4 Suggested Answers
  • 565 Answers
SOURCE: Dos mode not supported on Acer LCD
use run from startmenu and there write cmd then u can also use the command prompt
Posted on Dec 26, 2008
  • 51 Answers
SOURCE: window xp professional and LCD ACERX153W
get another monitor or put the drivers on your computer
Posted on May 10, 2009
  • 11800 Answers
SOURCE: fedora not working gui mode
The  x-server doesn't start. Try to start it thru command mode using the startx command. The cause for this is usually a bad xorg.conf file - the file that holds the configuration of the x-server. Just delete it thru command and a new one will be generated.
Posted on Jun 04, 2010
I connected my dvd player to my acer monitor - screen appears then signal appears input not supported?
That is because the resolution feeding the monitor is too high for the monitor to work, unless there is probelm with the monitor itself. The resolution of the video should be set to the native resolution of the monitor.
Mar 26, 2011 | Acer AL1916W 19" LCD Monitor
My monitor is an Acer 20". model # X203H I am using a MSI MEGA computer which has a VGA connection. My Acer monitor has two connections aVGA and DVI , I am using the VGA connection from the ACER Monitor...
There is both an analog and digital setting on your monitor settings. Bring up the monitor settings and toggle between the digital and analog settings until you get a signal.
Sep 13, 2010 | Acer Computers & Internet
I have an X153W I can not get any sound from it ?????
Acer X153W Series 15 LCD Monitor
This model does not have internal speakers.
You will have to get some external speakers.
Hope this helped
B52Computers
Dec 05, 2009 | Acer 22" X223w LCD Monitor
Graphics error
Hello, I dont think you need a driver for you lcd screen. If your resolution is low you need drivers for your graphic card. what card do you have ?or computer?
May 13, 2009 | Acer AL2017 20" LCD Monitor
Window xp professional and LCD ACERX153W
May 10, 2009 | Computers & Internet
Hi There! My Acer x223w monitor is floating a "Input Not Supported" box that will not go away any suggestions?
The documentation for this monitor should list its supported resolutions, and you will need to attach another monitor that supports a greater (possibly lower or higher) range of resolutions and then set it to one of the supported resolutions for the monitor. The native resolution appears to be 1680x1050, although I cannot find online documentation directly from Acer.
May 04, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Monitor driver for acer lcd x153w
go to the following link and u can download it there
http://support.acer-euro.com/drivers/downloads.html
Dec 29, 2008 | Computers & Internet
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
