Question about Samsung Microwave Ovens
Defrost Instructions for Samsung Timesaver 850W Microwave oven
4 Suggested Answers
SOURCE: microwave oven is getting poer but nothing getting heated up
I am facing the same problem. The light and display is working fine but not heating. I have a kenstar product.
I tried calling the service station in my city but the Phone no. no longer exists.
Can anyone suggest me something on this. Please help.
Posted on Aug 12, 2008
  • 686 Answers
SOURCE: user manual
CHECKTHE FUSE :)))
Posted on Apr 18, 2009
  • 6771 Answers
SOURCE: have a samsung timesaver 850w
The letters S E indicates "systems error" usually caused by a short in the keypad membrane, the only solution is to have the keypad replaced to bring it back to normal.
Posted on Apr 07, 2011
Microwave showing S E on screen an not responding ,, samsung timesaver 1000
I always advise people not to buy ANY APPLIANCE with the too many fancy buttons and programmes E.T.C.all you need is plain and simple ....less trouble but without seeing the appliance I cannot offer advice sorry!!!
Oct 24, 2017 | Samsung Microwave Ovens
Message on samsung timesaver microwave 1000w 5E what does this mean?
The code indicates a possible shorted membrane switch. Unplug the unit for at least 30 minutes to see if the code clears. If not, you might actually have a shorted switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 28, 2017 | Samsung Microwave Ovens
I have a Timesaver 1000w Samsung microwave. Just started to get error messages of p2 and p1 as I have lost the manual a long time ago could you explain what these codes mean.
There are no user serviceable part on a microwave and the screws holding the case are security screws. You are better off taking it for service.
There are fault codes here, but no P codes.
Microwave Fault Codes
Jan 20, 2016 | Samsung Microwave Ovens
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
Samsung timesaver microwave
follow this steps and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#2#ixzz2YxACIG9d
Jul 12, 2013 | Samsung MC5694 Microwave Oven
Samsung timesaver 1000w microwave turntable has stopped turning
Possible that the belt has failed, the motor has failed or the fault is the drive in the board. You need to start by checking the belt and motor.
click this link: Motor replacement
Apr 10, 2013 | Microwave Ovens
My Model is Samsung timesaver 1000 W, M1934NCE. Made in malaysia, September 2002. No power at all. Completly dead. Please help me to fix this.
possible solution
checkpower unit like fuse
check transformer which gives different supply to various part of oven
May 15, 2012 | Samsung Microwave Ovens
Have a samsung timesaver 850w it has just come up with an error message either 5 E or S E have tried turning it off and on but still cmes up. cant find my booklet
Apr 07, 2011 | Microwave Ovens
User manual
CHECKTHE FUSE :)))
Apr 18, 2009 | Microwave Ovens
Microwave oven is getting poer but nothing getting heated up
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | Samsung MW880KSA 800 Watts Microwave Oven
Microwave Ovens Logo
288 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
