Question about Altec Lansing M302 moondance HOME Alarm Clock Radio for iPod
How do you set the clock on the Moondance Home - M302?
Hallo
First you have to select "source" iPod, or Aux.
Press "time" 3 sec.
Choose "12 hr" or "24 hr" press "time"
Change with "Snooze" up or down etc.etc.
Close with "time".
Succes
Posted on Nov 12, 2010
Set the clock to DST, on my GE JRP20 B wall oven
set the clock to a new time:
TIMER/CLOCK Pad
To set the clock, touch this pad twice and hold 3
seconds and then touch the + and - pads. The
time of day will flash in the display when the
oven is first turned on
Mar 22, 2017 | GE Home
I need amounting brack for my icom ic m302 vhf marine transceive where can i get it
Try Ebay as a source. I have had good luck finding such accessories for reasonable.
Aug 20, 2014 | Icom IC-M302 VHF Marine Radio
How to Set time on a rth6500wf
Press Done on the thermostat if you aren't at the home screen. Then press Set Clock/Day Schedule at the bottom left of the touch screen. Then use the up/down arrows on the right to set the time. Press Set Day (second from the right on the bottom of the touch screen) then use the up/down arrows to set the Day of the week. Press Done to exit the set clock menu. (Alternatively, press Set Schedule to continue to set your thermostat to your daily schedule.)
Honeywell has the manual available on their site: http://yourhome.honeywell.com/home/ . Enter the model number in the search box to find the available manuals. See page E36 (28 of the PDF).
I hope this helps.
Apr 25, 2014 | Honeywell Programmable Thermostat Heater
How to set the time
Press "time" and hold 3 sec.
You can change the date and year this same way.
Nov 15, 2010 | Altec Lansing M302 moondance HOME Alarm...
I'm trying to change my radio station. The instructions say to push the snooze up or down arrows. But all that does is change it to one preset station to another. I don't want the preset stations.
For me with the M302 moondance system, the remote Tune + and Tune - buttons change the FM station (when the unit is set to FM as the source). Press and hold for 3 second to scan to the next clear station. The Track Forward and Track Backward switch between the presets.
If you are using the buttons on the unit, you can only search through the preset stations with the Snooze Up and Snooze Down. If you do not have the remote, you need to replace it. I believe this is the correct one: http://www.alteclansing.com/ae/restofworld/accessories-parts/wireless-remote-m302-a13547/invt/a13547/ .
I hope this helps.
(btw the manual for the M302 is available here: http://www.alteclansing.com/ae/restofworld/ipod-iphone-speakers/moondance-home-m302/invt/m302/ . Click on the icon with the down arrow.)
Nov 11, 2010 | Altec Lansing M302 moondance HOME Alarm...
IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
May 17, 2010 | Icom IC-M302 VHF Marine Radio
Can the Microphone be replaced on a ICOM M302 Radio
The MIC is available with the cord from Icom or me (847-746-0100) It is not easy for the novice, it must be routed through the front panel and plugged in to the circuit board inside. Not impossible to do, just tedious. Also, my wild guess is about $50 to buy the mic, so, not worth it if you pay labor!
Jan 09, 2010 | Icom IC-M302 VHF Marine Radio
How to make the digits dimmer?
You can do this by using the snooze buttons,
Any idea how to reset the clock?
Jul 19, 2009 | Altec Lansing M302 moondance HOME Alarm...
Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Mar 17, 2008 | Refrigerators
Altec Lansing M302 moondance HOME Alarm Clock Radio for iPod  Logo
793 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
