Question about Linksys WRH54G Wireless Router
How can i troubleshot linksys wireless router cannot give internet access?
5 Suggested Answers
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
tech curly
  • 298 Answers
SOURCE: LInksys wireless router stopped working
Who is your internet service provider and what is the model no. and brand of your modem?
Posted on Jun 01, 2008
  • 53 Answers
SOURCE: Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Posted on Nov 06, 2008
  • 211 Answers
SOURCE: How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Posted on Jan 10, 2010
I can't connect to the internet wirelessly. i don't think my linksys router is working
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 29, 2012 | Linksys Computers & Internet
Setup and Connected a Cisco WRV210 Router on a sm business configured for LAN of 15 DHCP WrkStns. Configured Router to connect to ADSL pppoe with "keep alive" selected. Connects to Internet...
Simple fix, this router is discontinued and you should take it back to the store to get a different one. Because it is a discontinued model they should easily refund or replace the item.
May 02, 2011 | Linksys WirelessG VPN Router with...
Will not connect to internet whether it is wired or not
connect the broadband modem to the internet port of your router (probably is blue). Then connect your pc to the router.
You have to set your router to act as dns.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
My router does not recognize the internet when I am setting it up, however, I can still access the internet through wireless connections that go through the router. I go through the setup process, and the...
I think you are trying to set up router using the Cd program or Linksys Easy Link advisor program. This program has some bugs. It will show you that you are not connected to the router but you are online. Some times it will show you that there are some other people connected to your wireless network but there are not.
So if you are trying to run that program then you don't need to use that program. Even if you call the Linksys tech support number , no one will give you proper answer for that.
you can set up the router manually without the CD.
Click Here for more information about the routers and the network
Jan 14, 2010 | Linksys Wireless-G WRT54G Router
Hawking Extender- Connected to WiFi but cannot access Internet
First think I always do is Reset Linksys Router and disconnect extender. Then turn off all security on router. Do soft reset on ipod. leave extender off and see if you can connect to the linksys. If you can then plug in extender (still with security off) then see if ipod connects to extender.
you might have to soft reset ipod again once you connect the extender.
if that works. reset security. Let me know how that goes.
Jan 01, 2010 | Hawking 802.11g Wireless-G Range Extender
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Lost connection to internet after 2 days
I ran into the same problem when i was living in Reno.
I fixed my problem by First, Access Command Prompt, by way of Run Program: CMD
then i inputed the command ipconfig /all
Find the wireless portion in the information that it gives you, what you are looking for is the Mac Address. it should be 12 total Alpha Numeric string, which is seperated every 2 by a dash marker.
Next, access the router through the normal way of browser, In the Wireless section, there is a tab that you select to input the Mac Address into the router, to basically give the router a permission to always give that computer access to the internet. This worked for me. I do hope it works for you. Its what i have always done in the past when i set up wireless Offices
Oct 28, 2008 | Linksys Wireless-G WRT54G Router
Bridge mode
in the linksys 54gr in that you have to give the mac address of the router and made a repeater mode so you can get the internet
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
Desktop/labtop - want to use internet with both at same time
check to see what your router setting is for "IP range" under the DHCP section. If it is NOT setup as a DHCP server, then enable this and put in a range of for example : 192.168.1.2 through 192.168.1.10
This will give you the availability of 9 connections. Also,.. be sure that your computers are setup to have their IP assigned automatically ( unless you NEED a static IP )
You should be able to access these settings by opening a browser and typing in the address 192.168.1.1 ( linksys default )
Hope this helps,.. I only came here to find range specs of wireless N routers :-P
Feb 23, 2008 | Linksys Wireless-N WRT150N Router
Linksys WRH54G Wireless Router Logo
20 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
