Question about Car Audio & Video
Check cd changer - Car Audio & Video
Ya and wires grounded right
Posted on Jun 16, 2008
Re-setting of cd changer
A couple of different possibilities here but this is a typical problem when it comes to the MB cd changers. Before ruling the cd changer bad, check the spring settings on the sides of the changer. Make sure they are in the 'H' position since it sits in the glovebox. The Mercedes cd changers don't have a reset button. 95% of the time its the cd changer that is bad when this scenario happens. Its caused by a linkage that gets knocked out of place internally of the cd changer. Also try not to use burned or homemade cd's as they can also cause the cd changer not to read the discs anymore.If your cd changer is brand new or a factory rebuild then the dealer should change it out no problem since MB cd changers are known for this problem. Also the version coding needs to done to configure the D2B fiber optic ring properly.
Aug 14, 2012 | 2001 Mercedes-Benz C-Class
Do they make adapters so the cd changer will fit
CD changers can be made to run on adapters.There are adapters availible that switch into the cigarette lighter socket with ratings of 50w,100w.Or else if its for a small cd changer, check current rating of the cd changer.ideally the voltager rating would be 12v.Then purchase an adapter with the given specific current and voltage rating.And use it with ur cd changer.
Sep 28, 2009 | Car Audio & Video
Cd changer problem
Refer to the CD changer manual & check this code or find the reset button otherwise take it to the workshop.
Sep 20, 2009 | Pioneer CDX-FM1287 12-Disc CD Changer
Pioneer cdx p1280 cd changer,the cd magazine will not eject.the power is all ok,tried the rest button bt still no go.
cd changer reqs a verygood 12v source,check for a good earth&check how many volts are going to changer with a good quality voltmeter,check at changer,not head unit
Jul 03, 2009 | Pioneer CDX-P670 6-Disc CD Changer
CD Changer not reading CDs
2000 bmw 528i,my cd changer also reads no cds,this seem to be a common problem with all bmw cd changer.Anyway i removed the cd changer from my car,took the outside black cover apart only to see that a white big wheel came of its place,(its the wheel that holds the cd in place from the top (bottom wheel is black attached directly to the motor,as the cd is sandwitched between the black,and white wheels) .if that wheel is out of place the cd will not turn inside the changer for the eye to read it,so your radio screen will read NO CD OR NO DISC.Very easy fix,just place the wheel in its place,and everything worked fine,it took me 20 minutes to fix.
p.s :
1- you do need to make sure you have an original cd in for testing it.
2- you do not need to recode your cd changer at the dealer if you have an old bmw,dealer will need to recode cd changers for 2006 and up.
Good luck.
Jun 15, 2009 | 2001 BMW 3 Series
How do you reset a 6 disc cd changer in 1999 VW Beetle?
1st just try unplugging the changer overnight. also check and see if a cd may be inserted into the cd mech itself.
May 15, 2009 | Alpine CHAS-634 6-Disc CD Changer
Chrysler Town and Country 2001
you need to check the fuse in the cd changer
Dec 10, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Replacement disc magazine
manufacture of make of cd changer but it would be cheaper to buy new cd changer i would think but worth you checking
Jan 04, 2008 | Audiovox SP11CDP 10-Disc CD Changer
CD Changer won't read CD
cd changer showing message display ERROR 2 . i CHECK THE MANUAL AND COMPLIED WITH ADVISE TO NO SUCCESS, WHAT IS WRONG
Nov 12, 2007 | Panasonic CX-DP801 8-Disc CD Changer
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
