Question about GE (GTS16BBS) Top Freezer Refrigerator
Hole in freezer
Unfortunately a hole was created in the freezer and there was gas leakage and also i have closed the hole.Now what should i do. waiting for your reply...
    Genius:
  • 1,036 Answers
Hi there!
Unfortunately the refrigerant gas has escaped, so will no longer function.
This appliance in now unrepairable, and should be replaced.
Check your home insurance, as you may be able to claim accidental breakage or loss of food due to refrigeration failure.
Sorry I cannot suggest a quick-fix for you.
If this information resolves the issue, Please take a moment to rate as Fixya. I know it's not repairable, but you needed to clarify that.
Posted on Jun 16, 2008
We have a whirlpool american fridge freezer leaking gas the engineer has been out 3 times , firstly we were told that the motor had blew one of the boards was replaced didn't work then motor repla
No! Gas leakage is only caused by bad joints, stress cracks or holes in the pipework. Also bad seals on the compressor.
The only 'motor' is the condenser fan motor. The other sort of motor is the Compressor.
I would cut your losses, ask them to recover all the parts installed and give you credit and buy a new refrigerator. The reasoning is that their diagnosis did not fix the problem.
Jan 13, 2018 | Whirlpool ET1FHTXM Top Freezer...
Everything at the top of my freezer has defrosted. The bottom is still frozen.
The freon gas is not circulating properly and there is a leakage in the cooling pipes. You have to call a technician and have the leakage located. Could be that gas is not sufficient.
May 14, 2011 | Freezers
My old Electrolux Model FI22/10B (frost free freezer), started freezing up. When i defrosted it, it had holes in the top part of the fridge and gas started spraying in my face. My landlord is now holding...
What you were looking at was the evaperator. If it was evenly froze up, it had a defrost problem. If it was just an iceball then it had a leak in the system.
Mar 30, 2011 | Electrolux Refrigerators
Fridge freezer freezer ok fridge warm willnot chill
dear sir/madam
i think there can be possible low gas problem it,s naturally if in your freezer there is low gas then it,s coil get warm. it,s coz of low gas so please contact to your service technician for find out leakage and brazing it and then refill the gas. i hope after that your freezer will work well.
hope answer the question
thank you
please vote!
Aug 30, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Ice is forming on bottom and back wall of freezer can any one help with this
there are two types of freezer, one is upright freezer (same as refrigerator on outside look but inside all the layers are same as the freezer of an ordinaryrefrigerator) the other one is the chest type freezer(basically it looks like a chest cabinet),now about the forming of ice at the bottom and back wall, well should be all side of the freezer should have ice on it,
Just one question to ask? Did you used any sharp object in removing ice(ex. knife, ice pick , etc,)
If you do then there are a possibility that you do some hole on the tubes where the Freon Gas (chemical refrigerant) are passing thru, then in that case you might have leakage. Well that means you really need to call a technician to do the job, because you'll gonna need to fix the hole and re-charge a freon gas.(having not enough refrigerant on the system, your refrigerator might not able to produce ice completly.
The other possible reason is that your motor compressor might be damaged(possible reason: Lost compression) it has something to do with pump compression inside the motor (only technician can solve this problem)
Oct 31, 2009 | Refrigerators
Ice is forming in the freezer due a small hole formed the freezer door.some say that the gas is leeking so it happens any solution?
you must close the hole otherwise you will always see the frost.Humid air comes from outside and creates the frost.Change the door gasket.Be sure it seals good.
Jun 23, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Sir,there is a small hole in my freezer part
Must be repaired by a "Certified" technician.
Apr 30, 2009 | Juicers
Hole in freezer
Time to get a new one. I take it you defrosted using a sharp object. Not the thing to do. Defrosting can be done with a simple device such as a hair dryer and do the system no harm.
Jun 16, 2008 | Freezers
GE (GTS16BBS) Top Freezer Refrigerator Logo
319 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
