Question about PC Chips M810DLU (M810DLUV75C) Motherboard
Audio Devices All of my audio is gone. Everything. I've done everything, it is almost like there was never audio to begin with. there is no sound card detected and there is no way for me to scan for it. ilosted all sound and manuel guide and thecd can't play if you want the serial tell me how to recognize it please help itried to use an extrenal sound card it works but suddenly it stopped working too my lastsound card is built in my motherboard ispc chips version 2.5vI
  • Anonymous Jul 30, 2008
    sound driver m810dlu window vista
On borad one proably no good i would get new x fi sound card use latest driver from web site those onbord ones dont last buddie thats nothing u can do erther come sup or it dont in device manger
Posted on Jun 16, 2008
My lap top is telling me I don't have any audio devices
if sound is working on laptop but not on skype, then the settings in skype needs to be set to you audio. go in to skype setting and audio and click on your audio and make it default, same for the mic choose the one you have and make it default. and click on save or ok when done.
Jul 04, 2017 | SMC Realtec Network Card NERENC01
Audio Devices
You need to remove device from device manager and to install back audio driver
Mar 05, 2008 | Compaq Presario 5000 PC Desktop
Sound card
As Acqwerty says, check your audio volume first, put the volume on everything up. Do you have an onboard or seperate sound card? If its onboard you have to make sure its enabled, this is done in the control panel, sound/audio devices. If its a card you put it, check the drivers, and make sure there are no other cards running on the same port as your soundcard, also done in control panel.
Dec 05, 2008 | E-Machines eMachines Desktop PC
Audio Devices
have you tried to install the drivers
Aug 12, 2008 | Toshiba Satellite A135-S4527 Notebook
I have no sound in my PC
BrendanG21, I had the same problem this morning. My sound actually quit in the middle of listening to music. Simply restart your computer (it may take a couple tries). If it's saying you have no audio device installed, but everything looks normal when you go into device manager, it's probably the same problem and this should work.
Running Windows XP
Dell B130 laptop
Sound devices listed under my device manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Jun 23, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Audio Devices
Somehow you must have either deleted you sound drivers or disabled them. you can start by looking in you control panel-sytem-hardware-device manager on the list should be something about multimedia audio controllers if there is a yellow arrow next to that then you must have removed the drivers and thus will need to download them from the manufacturers web site.
Mar 12, 2008 | Acer Aspire One PC Notebook
Tascam midi and audio conflict error
First try turning off the onboard audio device using the BIOS interface. Try pressing f4, f2 or delete key rapidly at the flash screen beginning when you first turn on the computer. Look around in the bios (usually in "integrated periperals" area) and disable any onboard audio options that you see.
-In windows XP you can go to Control panel - Sound Devices and change the "map through" feature, select your default device, and run a hardware test simulation with a microphone for each device. Nice setup btw.
Feb 26, 2008 | Tascam US-144 Sound Card
Audio Devices
no sound when i reformat my loptop lavie ll750ad
Feb 14, 2008 | HP Pavilion dv6000z Notebook
Audio Devices
Hi, Firstly if your sound card is not detected then either it needs to be re-seated or it has failed. Is the sound you have an actual card plugged into your motherboard or is it what we call "on board" so actually built in to the motherboard. If it is then you have a problem.
If it is an actual card you can open the box, make sure you will not be voiding any warranty you may have on the machine, then you can carefully unscrew the screw holding the sound card firm and pull the card from it's connectors quite firmly. So long as you don't twist or bend it you will not damage it.
Repeat the actions only in reverse to re-seat the card and screw back in firmly. ( If this does not get Windows XP to detect the card you could try another connector slot if you have one.)
Ok now to the drivers, once the card is detected WinXP will ask for the drivers if it does have them. You can follow the installation wizard and point to where you will have placed the downloaded files.
Ok downloading, can you tell me what the sound card is and then I should be able to tell you where you can download them from?
Let me know
Nov 27, 2007 | Computers & Internet
Audio Devices
Onboard Audigy Drivers
Onboard Sigmatel Drivers
try the audigy drivers first, all install instructions are provided on the download page, if it doesn't work, try the sigmatel drivers.
hope this helps,
Nov 19, 2007 | Dell Inspiron™ E1505 PC Notebook
PC Chips M810DLU (M810DLUV75C) Motherboard Logo
139 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
