Question about IBM ThinkPad R50e Notebook
GOOD MORNING SIR / MAAAM.. MY IBM THINKPAD R50E HAS AN ERROR ON THE SCREEN ..."ERROR 0271 CHECK DATE AND TIME SETTINGS'.. HOW DO I CLEAR THE CMOS FOR THIS ERROR? HOW DO FIND THE PASSWORD PADS ON THE MOTHERBOARD? PLS HELP ME.. TIA
  • IBM Master
  • 7,733 Answers
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS Battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new battery you can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the battery out or replacing it will get past your lock icon asking for the password. If not then you may have to find out the manufacturer of your computer's motherboard to see if there is a common password to get past the lockout. Since it's a laptop then it should be easier to find this code based on the manufacturer.
These links may help you with that:
How do I Reset an IBM ThinkPad BIOS Password?
CMOS Password locked on IBM Thinkpad
Posted on Nov 09, 2010
Unlock password
It seems to have a password set for that hard disk. Try using another hard disk. If you have the same issue, then there is some sort of password set in the BIOS.
Oct 20, 2013 | IBM ThinkPad R50e Notebook
T30 keeps giving me an Error 0271
Error 0271 Date and time error-Neither the date nor the time is set in the computer. Run IBM BIOS Setup Utility to reset the time and date.
I suspect the CMOS battery needs to be replaced.
Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise! Thankyou for using FIXYA! Bestregards,
Junior
Sep 23, 2011 | IBM ThinkPad T30 2366 Notebook
HI, I AM SANDIP FROM CENTRAL ACCOUNTS OF DURGAPUR STEEL PLANT A UNIT OF SAIL having IBM Thinkpad type 2682 ,Product Key GXR3W-GHM34-7RFFM-BVCQJ-WGF4G. PROBLEM- WHEN I AM SWITCHING ON THE POWER A ...
As soon as anything appears on screen after power-on, press F1 (keep clicking it until the BIOS setup screen appears). The first option on the list is Date + Time, click on that, and enter correct date/time. Then press F10 to accept + reboot. If this error happens again, it means that the CMOS battery (which keeps your settings alive) has died; it is cheap + easy to replace, however you have an R40 model, and I avoid working on Rxx series so that job may be harder. I could point you to the R40 service manual, which is very good to dis-assemble that laptop (it is necessary to lift keyboard to get to CMOS battery, which involves removing some screws from the bottom.
May 01, 2017 | IBM ThinkPad R40 2682 Notebook
I HAVE A IBM THINKPAD A22M LAPTOP WHEN IT BOOTS IT HAS A ERROR CODE OF 0271 CHECK DATE AND TIME SETTINGS AND BLANK SCREEN APPEARS AND A LOCK ICON APPEARS.... IT PROMPTS FOR A PASSWORD I DONT KNOW THE...
You will most likely have to remove the backup battery temporarily to allow the CMOS to clear the password lock.
The instructions for removing the CMOS battery are located here.
Be sure to disconnect the power cord and remove the standard battery when performing this work.
Be very careful to follow the directions exactly as shown.
You may have to leave the CMOS battery removed for a number of hours in order to clear the CMOS password.
Dec 29, 2010 | IBM ThinkPad A22m 2628 Notebook
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
Problem with ThinkPad T20
the internal coin cell battery has gone bad, it needs to be replaced.
Aug 04, 2009 | IBM ThinkPad T20 Notebook
Removing CMOS battery on ibm r50e is not solving the pass problem
Removing battery or resetting BIOS with jumper will not help. You should call IBM for support on this issue. All thinkpads have a three year warranty, with either return to base or on-site service. Since the R50e is a recent model, you should have no problem getting it serviced directly by IBM. Toll Free: 1-800-IBM-SERV (1-800-426-7378)
Jun 25, 2009 | IBM ThinkPad R50e Notebook
My IBM thinkpad A21e is showing me an error message
You need to replace your BIOS battery. The battery is old and cannot maintain the BIOS configuration. That is why you are getting incorrect date and time and bad CRC error.
Replace the battery and then configure the BIOS settings.
Jan 27, 2009 | IBM ThinkPad A21e 2655 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Jul 17, 2008 | IBM ThinkPad T21 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad R50e Notebook Logo
414 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
