Question about RCA F32650 32" TV
When I try to turn the TV there is a click and the green power light comes on for about 4 seconds, then the green light goes off , it then turns on again and then goes off, it then comes back on and then goes off. The sequence is always green light then flashing green light then off. I have tried the power switch ontop of the TV and the remote with the same results. There is no picture on the TV during these sequences. I have tied different wall outlets that I know are functioningand get the same results. Suggestions opinions????
    Top Expert:
  • RCA Master
  • 75,599 Answers
Hello
Your TV has horzontal output problem I thinks. It may be due to Line Output Transformer {LOT}; fault or its drive transitor fault. If LOT has trouble; its drive transitor also will get overheated,and finally will go leaky. You just open your Tv, and locate the line drive transistor mentioned above. It can be easly located very near to the LOT and will be three leged component, in black colour, screwed onto a metal heatsink to radiate heat out of it when working. Just resolder it out from the circuit board, and check it for colletor to emitter leak. Anyway replace it with a similar type and number, and see the effect. After replacing it, switch on the TV for just 5 seconds of so, and feel the heat gentated from it. It may be warm, but not get heated more. If it overheats, it is a clear evidence of LOT shor, and it also shoud be replaced with similar type and number. Insist on similar type and number for both the above said components, since they are critical parts of any Tv. Never use substitutions. They may work, but it will effect the clarity of the picture. OK.
Posted on Nov 09, 2010
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
Older medallion 55" 1080...switched itself
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Wont turn on. Green light comes on for a few seconds, andthen goes back o0ff.
Hi if its a Lcd or Dlp rptv most likely its time to replace the lamp if tv is between 2-4 yrs.If you hear clicking it could be the ballast which is the board that powers the lamp.Make sure fans are running ok ,dust them out if they are dirty.God bless you!
Oct 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
RCA F32650 32" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
