Question about Kenmore Washing Machines
Kenmore smart wash quiet pack 4, steam wash when washing clothes the number F35 keeps showing, what does that mean? 1/2 of the clothes are wet, other half dry
    President:
  • 1,554 Answers
The Central Control Unit detected a fault in the analog pressure switch. "Sud" may display 4 minutes prior to F35. Run a cycle without using detergent to clear possible sud lock condition. The first thing to check is the pump filter located behind the bottom panel. Remove the screws attaching the bottom of the bottom panel then pull the panel down and off the cabinet. Once the panel is off, remove the filter by turning the knob counterclockwise and clean the filter. Reach in the pump impeller with your finger and turn it manually to check it for restrictions and damage.
The next thing to check is the analog pressure switch assembly. Remove the screws attaching the top panel to the rear of the machine then slide the panel backward and off the cabinet top. The analog pressure switch on the top right rear of the cabinet with a clear hose attached to it. Check the hose for clogs and kinks then detach and blow air forcefully down through it to clear for any obstruction. Also blow air into the pressure switch itself to release possible contact bonding.
Posted on Nov 09, 2010
I have a Kenmore smart wash quiet pack 9 HE5t and when I try to turn it on it make a noise but won't turn on
Please check the motor belt , the drain pump and the inlet valve. If the noise seems to come from any of these it is possible that it trips off the circuit due to a fault and so must be confirmed.
You can remove the connection to the seperate items to confirm if the panel switches on.
Jul 02, 2012 | Kenmore Elite HE5t Washer
He5tsteam kenmore elite smartwash quietpak9 keeps flashing F35
Analog sensor failure. Replace that puppy using this VIDEO GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | Kenmore HE5t Steam 4.0 cu. ft. Front-Load...
My new kenmore washing machen is not working it shows F35
you need a new pressure switch more than likley its flashing sud before giving you a f35 too right?
that is a very comon problem with the steam washers
if you take the lid off and look to the rear right you will see it
it is small black and dark orangish redwith a hose attached to it
Aug 23, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE 5T Steam Front Loading Washer keeps flashing the code F35. What does this mean? It is not in the manual.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Smart Wash HE3+ steam washer that is showing a F35 code. What does that mean
Aug 31, 2009 | Kenmore Washing Machines
Keep getting f35 code on quiet pak 9 washer
F35,= SUDS
set a few washes without using any soap to flush the pump out.
Use less detergent and use a liquid rather than powder.
Aug 25, 2009 | Kenmore Washing Machines
F35 code appears, even after changing the steam chamber.
IT IS THE ANALOG PRESSURE SENSOR NOT THE STEAM CHAMBER.
May 27, 2009 | Kenmore Washing Machines
Washing Machines Logo
102 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
