Question about APS20B Prestige Keyless Remote Alarm
How do i set time and other settings on my prestige remote?
2 Suggested Answers
  • 19 Answers
SOURCE: I just got a prestige pager alarm for my car. how
hold down the F button 3 seconds then hit it again to advance to the clock mode, use the lock and unlock buttons to toggle the feature up and down. regards, martin @ lessco electronics
Posted on Jul 29, 2010
My preinstalled remote starter on my truck has a combination/sequence that the dealers salesman could not get roght bit twice to start pickup. im looking for fimiliar combination/sequences that my seem to...
If you have to press the vehicle's door lock AND the remote starter button...something is definitely wrong with the installation. If the prestige is a one button unit, try pressing the button twice within two seconds to start vehicle (press...thousand one, release, press...thousand two,release) this is the default setting.
Aug 05, 2012 | Prestige Remote Start
How do you set clock on prestige microwave model sde23r
how to set time on prestige microwave sde 23r
Jul 02, 2012 | Microwave Ovens
How do i set the time (clock) on a prestige SDE23R Microwave?
To set clock press "clock" then "cancel" input time in 12 hour format ie 01 00 for 1am or 1pm then "clock"
Jun 13, 2012 | Prestige Appliances Microwave Ovens
Installed the prestige remote start(aps687n) on my 95 jeep grand cherokee but when i try to remote start my parking lights just flash 7 times and nothing happens. Any ideas???
Yes, the seven flashes mean that the tachometer setting has not been programmed. If you hooked up a tach wire (green with orange stripe) to an uncommon coil or injector wire, then you have to program tach: turn ignition on, press and release programming switch three (3) times. The parking lights will flash once to confirm. Turn ignition off. Press and hold programming switch. While holding the programming switch, start the vehicle. The parking lights will flash to confirm that the remote starter is getting a tach signal from the vehicle. Continue to hold the switch for approximately 15 seconds.The parking lights will continue to flash while holding the switch. Release the programming switch. The parking lights will come on solid for one second, then go off. The tach is not programmed. Turn ignition off. Test system.
Sep 19, 2010 | Prestige Remote Start
I need to know how to set up a key fob for Audiovox PRO-OE2C4S
TURN KEY ON
THEN PRESS VALET SWITCH 3 TIMES
THEN PRESS LOCK BUTTON.
TURN KEY OFF
Jan 04, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I just got a prestige pager alarm for my car. how do i set the time on the pager remote?
Nov 20, 2009 | APS20B Prestige Keyless Remote Alarm
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
APS20B Prestige Keyless Remote Alarm Logo
1,857 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
