Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
My Fisher Paykel AeroTek OD302 double oven has failed, the lower oven no longer heats after using the self cleaning cycle. I've heard that there is a "field" temp reset that has to be performed by a service technician. Anyone know what this procedure is? Also, would like to know where the serial number is... don't want to have to pull this wall oven out of its mount without knowing where to look for the serial number.
Ovens Fisher&Paykel takes a long time to warm up.
What could the problem
Posted on Feb 16, 2011
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Dec 05, 2016 | Fisher and Paykel Ovens
After using self cleaning oven temp will not rise above 80?
call your local repairman something melted from the excessive heat of self cleaning
Mar 12, 2016 | Fisher and Paykel AeroTech Double OD302...
Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
Bottom oven not heating up and I replaced element behind rear panel.
U have a bad fuse witch is located in back of oven .its round and black .replace that first .if that don't work then your selector switch is bad .or your control board.what ever u.one u use to turn on the oven
Nov 08, 2011 | Fisher and Paykel AeroTech Double OD302...
Bottom oven not heating. Both light and fan are working.
If fan is working o/k then it is usually the oven element that is faulty, this should be located at the rear of the oven compartment behind a removeable cover.
Dec 11, 2010 | Fisher and Paykel AeroTech Double OD302...
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
Our Fisher Paykel OS302 completly overheated during its cleaning cycle. Oven door is locked, nothing comes on and Fisher Paykel will not help, it is only 4 years old, we have made many calls, and certified...
The thermostats have probably blown. There is a rebuild kit for this problem, it is not cheap nor is the labor to do it. Try shutting off the breaker for a few minutes... sometimes it will reset, but not heat. In any event you should have the new thermostat kit installed. F/P should at least be able to give you the tele. of a Tech., keep in mind that depending on where you live there are very few technicians that are certified to fix these.
Jul 08, 2009 | Fisher and Paykel AeroTech Double OD302...
Open Questions:
See all Fisher and Paykel AeroTech Double OD302 Electric Questions
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
791 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Joseph Hoffmann
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
