Question about Quantaray QSX-DigiPro 8500 Tripod
Extention tube the center tube has two pieces and if I can buy another lower piece I could extend the hight another foot. Do they sell parts for this tripod?
  • 2,794 Answers
Not for that particular way. The only thing you can do is put it on a higher platform.
Posted on Jun 16, 2008
Where do I put oil
Oil is placed where there are two pieces of metal rubbing together.
1. You must look for moving parts while moving the hand wheel. 2. There are some holes on the frame to give you access areas that need to be oiled..
3. The bobbin rides on an indented area called the race. Place one drop at this location frequently.
4. The motion of the needle arm going up and down between two holes needs to be oiled.
5. The pressure foot has a movement of a steel tube (arm) that needs oiled every now and then. The up and down motion of the pressure foot switch has two pieces of steel rubbing together in order to raise and lower the foot. It is important to oil here and on the spring that is inside the tube.
Anyway; make sure you look for steel against steel and oil it.
Jun 28, 2016 | Sewing Machines
Repair your infra red heater thermocouple,do not buy one
The most common problem,for a infra red heater is the thermocouple.Not always,but if you look at the thermocouple,and it is no longer in the flame of the pilot lite,then it is the problem.The thermocouple has to be in the flame of the thermocouple,so ,to do that,you have to fabricate an extension,so that it will be in the flame of the thermocouple.I have found that a piece of tubing,such as steel brake line,works the best,use a tubing cutter,and cut a piece off the end of the steel brake line tubing.Figure out ,about how long it would have to be,to reach the flame of the pilot lite,and cut it,then just slide it over the top of the thermocouple,on the tip.The size tubing that you will need is 1/4 in .Any,and I mean any,auto parts store will have this,for about$ 2.50 or $3.00,get the shortest piece they have,most likely a foot.This tubing will heat up,therefore,transferring the heat ,to the thermocouple tip.There,you have done it,all by your self,and saved about$ 65.00.Labor,and parts.And the time involved waiting for someone to fix it.It is perfectly safe.So get to it america,fix it your self.
on Jan 13, 2010 | Heating & Cooling
I want to find out some rubber tube excess in carburator section how can i connect
Snip a small piece of the line off, enough to measure the ID and OD, and take it to a parts store. All auto parts stores have rolls of fuel and vacuum line and sell it by the foot. As the lines begin to harden and crack with age thereby making many small vacuum leaks, it is beneficial to just replace the line with a new one instead of trying to stretch the old one.
Nov 18, 2010 | Mitsubishi Galant Cars & Trucks
I have 95 cutlass and the radiator leaks from behind the hose everytime i stop, the bracket doesnt seem to press tight enough on that side, how do i fix this? I tried to tighten the bracket but the...
place a piece of ruber tube behind the bracket
like a piece of old ruber hose or buy a piece of ruber hose from local auto parts store if needed they will sell it by the foot
Aug 03, 2009 | 1995 Oldsmobile Cutlass Supreme
What is the tubing size for the windshield washer
simple solution is to take a piece of the tubing into any parts store and have them size it for you. Typically you can buy it rubber tubing by the foot. or, measure the inside diameter - the size of the inside hole - with a tape measure. But, then refer to the inside diameter when buying tubing.
Jul 12, 2009 | 2002 Mercury Sable
Broken part on coffer maker
Replace it with the same sized tubing that you can buy at the Hardware store. just get the length you need they sell it by the foot. DFD
Apr 20, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Center water tower came apart
There have been many versions of the spray tower used over the years. If you have the model HDA3400G which you posted under, you should get a part number WD22X10008 which is the lower spray arm and tower assembly. By looking at the new part, you will see how a couple tabs hold the part on, and can figure out how to remove the old one with a flat blade screwdriver (or two). If you have a different model, please post the exact model number. The model number sticker is generally located on the left side wall of the tub, right by the front.
Apr 19, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Trying to find a part number for water tube from door of freezer
if the tubing is bad you might try taking a piece to your local hardware or building supply store, you can buy tubing by the foot and make your own.
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dishwasher needs repair
Bonnie, the spray arm itself will have a tower that extends upward. On the lower rack in the center will be a tower protector and the upper rack should have a water diffuser in the middle. The protecter and diffuser will clip on to the center of the racks. Hope this gets you going..
May 28, 2006 | Roper 24 in. RUD5750DB Built-in Dishwasher
Quantaray QSX-DigiPro 8500 Tripod Logo
75 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
