Question about Nintendo Wii Console
Im kinda new to computers and all but im trying to hook my wii to the internet but i keep getting error code 52030 whats going on?i have a 2wire router
    Sergeant:
    Champion:
  • 286 Answers
Error Code: 52030
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
3.
If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
4.
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
5.
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
1. On your PC, click "Start" and then "Run."
2. Type "CMD" into the field that appears to open a new window.
3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
This extract comes from Neoseeker. com.. Hope it helps.
Posted on Apr 14, 2011
Can not connect to internet on my wii error code 52030
It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console
Jun 04, 2012 | Nintendo Wii Console
Error 52030 We are trying to hook up with the internet to get Netflix through our WII
Hello there!
The Error 52030 means that the Wii is having trouble connecting to the wireless network. Here are some solutions that might fix the issue. I hope this is helpful. Thumbs up are always welcome :)
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
May 03, 2011 | Video Game Consoles & Games
When I try to connect to the Internet it keeps giving me a error code 52030
Error 52030 is a security settings error built into the Wii. This means the Wii is either incompatible with your router's security settings or your router isn't able to assign the Wii an IP address (which means it can't register it onto your network).
Nintendo has provided official information for solving this problem here: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
Mar 12, 2011 | Nintendo Wii Console
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
Feb 28, 2011 | Nintendo Wii Console
52030 error message when trying to hook to the internet
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jan 23, 2011 | Nintendo Wii Console
I am trying to connect the Wii to the internet. I get Error Code: 52030 What do I need to do?? Thank you
One option is try choosing a different type (1) for your password...I've had the same error as you before and what I did was to change the password type e.g. From wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right after started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Hope It Helped
Jan 16, 2011 | Nintendo Wii Console
I have an Error Code 52030 on my WII. What does
it means that u are trying to connect to wifi but there is no wifi around so go 2 tech support for wii and enter the error code.:)
Jan 30, 2010 | Nintendo Wii Console
Okay, in the Nintendo Wii I go to the Wii Shop Channel option and try to go, but a screen appears saying that I have to configure the Internet settings with the options QUIT and ENTER SETTINGS. I click...
OK what is your wii connecting to some wireless routers cant handle more than one system (computer) next try to move the wii closer to the route, and make sure your wii is not around any thing that creates wireless inter fearinces
Apr 24, 2009 | Nintendo Wii Console
Error code 52030
I'm not sure if this is the case, but don't plug the WiFi adapter into the Wii console, plug it into the USB port in your computer. If you are plugging it into your computer, there might be too many walls between your computer and Wii, in that case get a USB extension cord.
Mar 29, 2009 | Nintendo Wii Console
Error 52030 in internet connections
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Nov 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
