Question about ECS C51GM-M Motherboard
C51gm-m - ECS C51GM-M Motherboard
ECS C51GM-M user manual
Hello
Here is the place to load your manual in the lower area you will see
a header called download that's your spot just pick your language and load it to a spot on your computer, I like my desktop for these type's of things then you can print it out if you wish.
Good luck and be safe.
Mark / aka RagenRat
ECS Web Site C51GM V1 0
Feb 18, 2013 | ECS C51GM-M Motherboard
C51gm-m esc motherboard need divers for windows 7
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
hope this helps
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
Mar 28, 2012 | EliteGroup C51GM-M Motherboard
Hey who ever this is im having bad problems with my motherboard or my bios ive tried everything i got ECS C51GM motherboard with the 6100 nvidia video display. icant run any full screen programs cause it...
Its not a bios problem but on insertion of video card your ram got some tampered. Just reinsert the video card and your ram properly and now start your system. It might solve your problem.
May 20, 2010 | ECS C51GM-M Motherboard
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
Realtek ALC655 · AC97 Audio Codec download for C51GM-M m/b
The audio codec is the sound driver software for the motherboard.
Click on the link provided;
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?CategoryID=1&Typeid=35&detailid=653&DetailName=Driver&DetailDesc=C51GM-M(V1.0)&MenuID=39&LanID=0
Scroll down to Sound: RealTek Codec Sound on board driver.
Create a folder on your desktop & name it RealTek. Download the file named: realtek.zip into the RealTek folder. When finished open the folder & uncompress the .zip file. You may need the program WinZip to uncompress the file. If you need WinZip you can download the trial version for free at this next link;
http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Uncompress the file into your RealTek folder. Open the folder & find the setup.exe file & run it.
If this fails to install double check your bios settings. Use the manual to help you. Make sure the bios setting for AC97 is set to [Enable] or to [Auto]. Failure to set this bios feature will cause windows to prompt you for the codec software.
You can post here if you still have problems.
Thank you for using Fixya
Mike
Jun 23, 2009 | EliteGroup C51GM-M Motherboard
Video controller drivers not found
http://ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?CategoryID=1&Typeid=35&detailid=653&DetailName=Driver&DetailDesc=C51GM-M(V1.0)&MenuID=39&LanID=9
That is the nvidia driver you need.
However to get it to work right boot into safe mode, uninstall the Windows generic drivers, cancel the auto install and then run this driver's install program.
Sep 17, 2008 | ECS C51GM-M Motherboard
No sound C51GM-M motherboard.
Is the sound card enabled in the bios?
Dec 23, 2007 | ECS C51GM-M Motherboard
C51gm m
I had this problem. It was a continuous series of slow beeps. It was a memory problem. I swapped the memory and the system booted.
Sep 13, 2007 | ECS C51GM-M Motherboard
ECS C51GM-M Motherboard Logo
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
