Question about Apple Power Mac G4 Dual Mac Desktop
My mac is playing up!!!
Every time i start my mac G4 up, it takes at least an hour until i see anything on the screen, and then i get asked to register my mac and asked to follow several commands regarding my service provider telephone number etc and this also takes another hour or like last night not at all. the real problem is, that my mac once had indesign photoshop etc , and now i can not see any of these on my mac!! Please can you help me!
    Problem Solver:
  • 5 Answers
Cannot see apps is a generic fault description. Try the following you may get lucky. Scenario 1 you have no backup. Boot up from os disk and select disk utiliity from the tools menu. Check drive status from high-lighting drive manufacturer  and checking smart status. Degraded or anything other than Verified you are stuffed dont risk disk repair it could make things worse. Best reboot holding T button (Target disk mode) and connect to another mac via firewire and backup if you can any data immediately. Concentrate on User folder. Replace drive and go to Scenario 3.
Scenario 2. You backed up.If  Disk Utility will not repair volume. Best get a copy of Disk Warrior. If disk structure repaired and still will not boot up properly reinstall system with import user option.
Scenario 3. Give up trying to get data. Boot up from os disk. Reformat and install system and reside yourself to being a plonker for not backing up. BACKUP BACKUP BACKUP. :)
Posted on Jun 23, 2008
Screen size too large
Click the Apple logo button in the top left corner of your desktop.
Then click System Preferences.
Click Displays under Hardware.
Play with the screen resolutions there until you get what you like.
Jan 26, 2014 | Apple Mac mini G4 Desktop
My Powerbook G4 internal is almost full, which is why I was backing up a couple of days ago. I was removing various large programs I don't use. My Trash would no longer empty, I could not print and tried...
Take the RAM out and reinsert and see if that does anything. Install RAM you know that works into the two slots and see if that does anything.
Install disc 1 of the 2 gray discs and press the option key to boot from the disc-Then go into the disk utility section-then click on repair disc permissions-then click on repair hard drive disc and see if that does anything.
Oct 11, 2010 | Apple PowerBook G4 Mac Notebook
I have a apple G4 book and when I start it up it will not go past the apple sigh and the screen stays blue?? Help Please
Hello and thank you for contacting Fixya Support, I am glad to assist.
I recommend you boot your Mac into Safe Mode, to see if you can remove a possible folder(s) which may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
I hope this helps. If you have more questions, please feel free to reply back to this post.
Regards,
Mactechtrainer
Sep 27, 2010 | Apple iBook G4 Mac Notebook
My Mac G4 Tower, 10.3.9, suddenly lost all color. The display is black/white, shades of grey. When I start to boot up the screen starts blue but then goes to grey. This happened 2 days ago after a nearby...
The wether does have something to do with it. After a lightning storm humidity is a problem. the humidity and heat can make the screen lighter, kind of grey. After the wether clears up it will take an hour to regain full color. Also it could be if it was charging while the storm happened it could have blown a fuse and messed up you screen colors
Also try to gain color by
Control+option+command+8 (negativity)
Control+option+command+< or >
color tinter
Jun 27, 2010 | Apple PowerBook G4 Mac Notebook
When you turn the comuter on, it just shows the
--SAFE BOOT MODE--
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• This path, is going to take you to the System Library folder which has all of your Mac OS X StartupItems.
This should help get your iMac G4 back up
and running.
Regards,
Mactechtrainer
Jan 30, 2010 | Apple iMac G4 Desktop
My powerbook g4 is not starting. it opens the gray screen and just says i need to restart the computer. i tried restarting it and removing the battery a bunch of time and nothing is happening. HELP!!!
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Allow the Powerbook G4 to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Powerbook G4 and try just once more. It may have just frozen up the first time around for you.)
At times this procedure does help for gray screen issues so give this a try and let me know if this helps.
Thanks!
-Mactechtrainer
Jan 25, 2010 | Apple PowerBook G4 Mac Notebook
Disc will not eject
picexporterror Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
Oct 01, 2009 | Apple iBook G4 Mac Notebook
Mac not loading
Try resetting your pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Aug 28, 2009 | Apple eMac G4 Desktop
No screen on start up on g4 notebook
Try reinstalling MacOS on your laptop, as far as I know, all Mac come with recovery disks. To boot of off a disk, make sure the disk is in the drive , reboot the computer, and press C while the chime is playing. You SHOULD be able to reinstall. What your describing usually happens to very old iMacs that have bad, incompatible, or no RAM installed. If none of the above works, take it to an Apple Store, they were very helpful when my iPod had a bad battery
Aug 15, 2009 | Apple PowerBook G4 Mac Notebook
Apple Power Mac G4 Dual Mac Desktop Logo
51 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
