Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool model # GHW9400PL2 solution for the FO2 error indicator
    President:
  • 1,554 Answers
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Posted on Nov 09, 2010
Won't drain error code fo2
There is something stuck in your drain pump
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Going to Fo2
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fo2 on screen
your pump is jammed clean or, replace
Aug 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FO2 Error Msg
ok now ,,check why water is not leaving machine on time,,,check your drain pipe,,check the drain hose,,just blow in it and make sure a coin not stck there ,,the same with the waste pipe,,onthejob
Feb 18, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message FO2 keeps coming up
The F02 error code indicates a “long drain” If after 8 minutes of pump time the washer is not draining, you will get this error code. I would recommend checking the pump filter, drain hose, pressure switch & pressure hose. Be sure you are using HE (high efficiency) laundry soap.
Dec 17, 2008 | Indesit Washing Machines
FO2 AND SUD
hAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
Dec 23, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Suds then F02 over and over and over again
Most likely (it happened to many owners), you get the FO2 code, because some small items like socks got sucked into drain system.
Dec 15, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
286 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
