Question about Brother MFC-8440 All-In-One Laser Printer
Hi i have a Brother Mfc8440. for a while there was a sign that said toner empty. So i got a new toner cartridge rebuild kit. I tried to take all the ink out and to my surprise there was quite a bit that was still left in there. REgardless I put the new one in there and tried to test it. The same sign snowed up Toner Empty. So i tried the tape trick and it worked. But when I try to print there is barely any ink that is shown. Can you please help me. It doesnt really print with the ink.
    Genius:
  • 1,018 Answers
Okay, you are not going to like this but using the rebuild kit is the failure.
Go get a factory new cartridge and see what happens.
Don
Posted on Nov 09, 2010
Brother 1510 replace toner problem
Assuming you have tried to replace an empty toner with a new or refilled toner cartridge. Some of these machine simply fail to recognise the reset activation lever on the side of the cartridge. You could try removing the end cap at the geared end. You will find a half moon shaped gear which needs to be lifted out slightly and rotated a quarter turn clockwise. replace any other gears and refit the cover. This resets the toner cartridge to "new" state. If you printer doesn't recognise this, you will need to get a manual reset keycode from brother. Please note - some folk reset used cartridges this way and re-use them. Used toner will contaminate the drum and give poor print. Any residual contaminated toner on the drum can contaminate a new cartridge and so-on. Refilled cartridges are fine if the cartridge is completely cleaned out first.
May 06, 2015 | Brother DCP-1510 Laser Multifunction...
Toner light stays on after I changed cartridge
These are defects of Brother cartridges, even you put a new cartridge the toner empty still not reset. What we are doing is re-positioning the toner end cam on the side of the cartridge. You have to be knowledgeable with the machine to to that.
Apr 14, 2013 | Brother HL-2170W Laser Printer
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
www.tonerrefillstore.com
www.lasertekservices.com
They also have great customer service. I hope this helps!
Nov 08, 2009 | Brother DCP-7040 Laser Printer
Toner Cartridge empty
does the display come up as "toner empty x"? what is the last character after the toner empty ?
where x is:
c=cyan= 6,600 pages
m=magenta=6,600 pages
y=yellow=6,600 pages
k=black=10,000 pages
Jan 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Low toner/toner empty
Toner cartridges have more then just "toner ink" they also have developer and sometimes a chip that says how many times the cartridge has been used.
Also some refill places can be a bit dodgy so I know it might not seem like the best thing right now but try buying a real replacement cartridge and if that doesn't do it beg and plead to return it saying it was the wrong model.
If it does fix it then you might have a bad cartridge that either has the "chip" or the cartridge itself is simply worn out and in need of developer as well.
Apr 16, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc8440 clicking sounds while printing
I had the same problem when I used a refurb toner cartridge, had to replace cartridge with oem for it to print. After a while started making same noise, had to take it in to have parts replaced. Now I don't take any chances on non-oem parts, it's not worth it.
Mar 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Empty toner
usually new toners come sealed, you need to pull off this plastic seal. once installed shake it a little in case toner is clomped together
Jan 05, 2008 | Brother MFC 8600 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-1440/ flashing alarm light and flashing yellow data light
Brother MFC-8440 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
