Question about Dell Computers & Internet
I bought a used lapop
I dont know the security password to access data for this was told its fully functional and to erase or replace the hard drive , Ive heard there are over ride codes? do you know it and is this free or what is charge? thanks
    Guru:
  • 1,342 Answers
I lost my sandisk secure access password and want to recover my data or password...need help..please
i have'nt had the need to use this software so i dont actually know how it works http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Aug 02, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I forget my password to unlock my wd smartware
There is no way to unlock the software or hard drive without the password. All you can do is format the drive and erase the data to get functionality of the drive back. If you have access to the SmartWare software, but not the hard drive, you still have to erase the data and can use the software to do so. Here are some instructions:
1. Well, if you have the WD SmartWare already installed you are in luck as there is Erase function built onto WD SmartWare software. There are 2 ways. #2 or #3.
2a. Click to Settings Tab on 4th right.
2b. Click to Set Up Drive
2c. Click Erase Drive and follow the instruction.
3a. Plug in the drive and you will be prompted to type in password.
3b. Type in 5 "wrong/bad" password
3c. This will trigger Too Many Attempts and asked to accept data loss and get drive back.
May 09, 2011 | Computers & Internet
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password...
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
http://kb.sandisk.com/app/answers/detail/a_id/191
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Pen drive not opening and say format and not formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 04, 2009 | Fuji (MAP3367NP) 36.7 GB Hard Drive
I fogot my HDD password How to unlock
There isn't any way to recover or reset the HDD password or the Hard drive data. To use your computer again, disable all passwords in the setup and replace the hard drive, you'll lose all data.
Nov 03, 2009 | Lenovo Elite ThinkPad R400 Notebook
I just bought a sandisk cruzer and don't know how to set a password. From what I understand, sandisk allow you to set a password so that a password is need each time you wnat access to the usb drive. Is...
If your cruzer came with U3 then you are in luck. U3 can be set with a password that requires login before any data can be accessed. Just be sure you don't forget the password because it will have to be erased to reset it.
It can be downloaded from here.
Nov 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My pelco 16 cameras reset each one minutes
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Aug 25, 2009 | Pelco DX1000
Hdd password ,how 2 retervie
There are no backdoor passwords available. The password cannot be removed from the hard disk unless you know the original password to get into the hard disk and you can then remove the password.
Hard drive password is set to protect data stored on the hard drive from unauthorized access. Removing the hard drive and inserting it into another computer still will not allow access without the password.
If you cannot remember the password, your only options is to replace the hard drive with a new one and install Windows, the device drivers and your programs etc. to get a fully functioning computer again.
Jun 03, 2009 | Acer TravelMate 5720-6462 Notebook
I have a Verbatim Store N' Go 4GB Flash Drive
no solution but same problem. when I bought I erased everything on it and after some time use it protected itself. In my opinion because it has open pinouts one side wet finger may cause protection bur dont know how to unlock
Apr 15, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My flash drive is full, but when I put it in the USB port it indicates that there are zero files; however, under the properties it indicates the flash drive is full of data.
Im not sure how to fix the problem if you use windows, but if you use a mac then the steps below can help.  I use a mac and followed the steps below and now my flash drive is fully functioning again.
Connect it to the Mac.
Launch Disk Utility from Applications > Utilities.
Choose the drive from the list.
Click on the Erase tab.
In the Volume Format drop down list, choose Mac OS Extended.
If you want to Zero out the drive, choose that option from Security Options.
Click on the Erase button.
Sorry if this didn't help.
Jul 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
74 people viewed this question
Alun Cox
